Wiring For Wall Sconces In Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 10:55 AM   #1
Wiring for wall sconces in bathroom
In the middle of a master bathroom tearout and I'm changing the locations of my lighting. Is there a certain type of electrical box for wall sconces, since I'm sure the sconce mounts to the box and not to the wall?
bigburb is offline   Reply With Quote
Old 05-19-2009, 12:52 PM   #2
Usually, fixtures will mount to any kind of box. ! gang, 3/0 or 4/0
Sometimes they are a pain to mount to ANY kind of box due to the mounting hardware.
It's best to have the lights in front of you to dertemine which type to use. If that's not going to happen, I'd say go with a 4/0 (4" round)
220/221 is offline   Reply With Quote
Old 05-19-2009, 01:09 PM   #3
Ok thanks. I'm just trying to find out right now if I need to move a stud or not, a gang box would be perfectly on center with my wall, but just wasn't sure if a sconce would work with that type of box.
Old 05-19-2009, 01:53 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Unless you know exactly were you want your sconces, I would leave the cable with slack in the wall and then cut in old work octagon boxes after your vanity and mirror are in place. If the placement, ends up on a stud use a pancake box to mount your sconce.
Old 05-19-2009, 02:21 PM   #5
doesn't the weight of the sconce usually hang on the box? if the box happened to not land on a stud would it be able to handle the weight?
Old 05-19-2009, 04:45 PM   #6
A "Handy Husband"
rjniles's Avatar
I have never seen a bath sconce that would be too much weight for an old work box.
Old 05-19-2009, 08:31 PM   #7
a single gang box would be perfectly on center with my wall, but just wasn't sure if a sconce would work with that type of box.
MOST sconce canopies will cover a single gang box. Some smaller ones may allow the box to show a touch at the corners.
Old 05-20-2009, 08:23 PM   #8
Learning by Doing
Leah Frances's Avatar
I just installed two antique sconces in my bath. Plaster and lathe walls. I used a 4 inch octagon box and a generic round mounting bracket. I cut the holes tightly and used a couple of those metal finger-thingies to make sure the box was secure.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Help wiring bathroom fan. Elephantman Electrical 4 03-16-2009 08:10 AM
Wiring Problem in Bathroom notasparky Electrical 7 10-27-2008 06:34 PM
Bathroom Fan/Heater unit incompatible with electric wiring? bathroom nightmare Electrical 4 02-09-2008 03:41 PM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 06:25 PM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
