Wiring Wall Oven - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 10:17 AM   #1
wiring wall oven
I have removed the old oven, I could not get to junction box to disconnect wires. I cut them from the back of old oven. Is it okay to connet wiring from new oven to those of the old oven thhat are still connect to the junction box as long as they have wire nuts and tape?
roye is offline   Reply With Quote
Old 01-26-2012, 10:21 AM   #2
Julius793's Avatar
If every splice is in a junction box and same gauge wire must be used.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-26-2012, 10:32 AM   #3
MarginallyQualified
Rewards Points: 2,464
Is it okay to connect wiring from new oven to those of the old oven...
In principle... you should be OK.
BUT! I'm concerned about why you "could not get to junction box to disconnect"...
as this should not be difficult and probably should be fixed while you have things open.
Old 01-26-2012, 11:06 AM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Is it possible that the oven was wired directly to the home wire with no junction box/plug?
I have seen some people do that with a range and dryers. Not sure if it's legal.
I would try to find out while it's open and maybe install one. Leaving enough wire between oven and junction box to safely remove the oven for service.
rrolleston is offline   Reply With Quote
Old 01-26-2012, 02:49 PM   #5
joed's Avatar
Rewards Points: 11,998
Is the new range direct connect or does it have a plug on it?
Old 01-26-2012, 08:14 PM   #6
Rewards Points: 240
There might have been a junction box inside the old oven. Your new oven might have the same. But if the cable will no longer reach it, you'll have to do something else. If there's room, you can mount a new junction box in the back of the cavity and make the connection inside it. All wire splices and junctions must be inside a box.
fa_f3_20 is offline   Reply With Quote
How to get wiring into wall with tongue and groove panels npn_ Electrical 4 03-05-2011 05:52 PM
Wall oven too Wide for Cabinet victor07 Carpentry 8 01-03-2011 12:09 AM
Charred / melted wall receptacle, AL wiring in house creamaster Electrical 17 12-04-2009 05:47 PM
wall oven wiring quick question 205bhamjim Electrical 3 11-17-2009 04:01 PM
Oven wiring rodsteryz Electrical 1 12-26-2007 02:26 AM
