Wiring An In-wall Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 10:40 PM   #1
Unhappy
wiring an in-wall heater
We have a cadet series in wall heater ( 240v version ). The wiring instructions are lame, and the hours of their service department are even more lame.
We've searched and searched and searched, and can't find anything that tells us how to wire the circuit box correctly. I've got 12/2 wire going from our circuit breaker to the box. However, it calls for us to retask the neutral ( white wire ) to a live wire. Which means I've got to plug the white wire from the neutral bar into the circuit breaker.
But how? What kind of breaker is required? I don't want to undervolt it, as it won't heat the room properly. What kind of breaker to I plug in? I really don't want to take up TWO slots in my box, do I really have to?
I've wired the rest of my house. A TON of work. We even re did much of what a 'professional' did, and the inspector said the work was IMMACULATE. I'm not afraid of doing the right thing, but it seems frustrating to not find sufficient instructions.
mattkslc is offline   Reply With Quote
Old 03-04-2011, 11:03 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Yes you need to use 2 spots. You need (really should) to buy a double pole breaker. You need to check if this heater needs a neutral, if so you need x/3.
Did it spec 12 gauge? How do you know that is right?
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 03-04-2011, 11:18 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
What is the model # of your cadet heater? Or can you give use the amperage and/or wattage rating of your heater. With that information we can size the conductors and circuit breaker for you.
Your heater is rated at 240 volts so you need two hot wires and a ground. If your using nm-b (romex) that will be a black, white and bare ground. The white as you said will be re-purposed as a hot leg. It is appropriate to take a black marker and color the white wire for a couple inches at each end where it terminates in the breaker and connects to the heater wiring.
You will need a double pole breaker.
Your options with that will depend on your electrical panel make and model #... but regardless it will be a double pole breaker either full size or slimline style.
It will look like one of these depending on your panel manufacturer
Do not mistake a tandem breaker with a double pole breaker
http://www.drillspot.com/products/29...tandem_breaker
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-05-2011, 01:25 AM   #4
Both of these are from home depot. One is the 1500 Watt 240 v, and the other is 1000 Watt, 240 volt. The current wiring scheme has my 12/2 going from the box to the 1500, then a few feet over to the 1000 watt. I have those ends plugged in correctly.
I'm not certain on the box, but all the thingies in there are Siemens.
I definitely want the slimline. I'm running out of space, and can't afford a two-wide. Do they have 240 volt two-pole thingies?
Old 03-05-2011, 03:16 AM   #5
" Euro " electrician
frenchelectrican's Avatar
As far for Semins load centré please run us the model number for us so we can able determed if you can use the nonstandard dupex otherwise quad breaker. they are not cheap BTW but all it depending on the model number it will be on either the door panel otherwise the real legit number will be in the tub the label will be either side of the load centré.
Those thingie are circuit breaker it can be called single pole breaker or two pole breaker or tandam or twinner breaker each one will have diffrent meaning on how it useized.
The tandam breaker or twinner breaker or small two pole breakers are very tricky to deal we will get to that point after you verify us the model number of your load centré first.
Merci.
Marc
Old 03-05-2011, 08:27 AM   #6
I=E/R
a7ecorsair's Avatar
I have a house full of Cadet baseboard heaters and the instructions were sufficient for their product and their point of responsibility. Cadet cannot teach you how to wire a 240 volt circuit, they do not know the codes that apply, and, if I remember correctly, there is a statement saying it should be installed by a qualified person.
Follow the advice given for circuit breakers and yes, you will need to wrap some black tape around the white wire and connect it to the one side of a two pole circuit breaker. That is how you get 240 volts for your heater.
a7ecorsair is offline   Reply With Quote
Old 03-05-2011, 02:00 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Your siemens panel will not accept a thinline double pole breaker unless it is some older vintage with which I'm not familiar.
I would consider getting knowledgeable help to make the connections and choosing the correct breaker. Even though you wired your own home and an inspector said it was quality work it is a little discerning that you don't know what to call those thingies in the panel.... I'm not sure you should be fooling with wiring in a loadcenter with the cover off.
This much I can tell you ... your 12/2 g is fine for this heater branch circuit. A 20 amp double pole siemens circuit breaker would be good protection for the branch circuit.
Got any pictures ?
Stubbie
Old 03-05-2011, 09:11 PM   #8
Stubbie.,
In case you may why I did ask the OP for the modél number of the load centré due some of the Seamens panels I have ran into are pretty new and they do take twinners or quads breaker the key word is the model number that is the only correct anwer with this otherwise the OP is stuck have two choice either use the last two space for two pole breaker for electrique heater
Or the other option is put in subpanel if the exsting panel is about full.
Merci.
Marc
Old 03-05-2011, 09:28 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
................However, it calls for us to retask the neutral ( white wire ) to a live wire. Which means I've got to plug the white wire from the neutral bar into the circuit breaker.
And you say you wired your whole house?
I'd hate to see the work the "professional" handyman did.
Old 03-05-2011, 10:19 PM   #10
Licensed electrician
Rewards Points: 1,484
If they can't afford that double wide thingie how will they afford to operate the heaters?
Tags
circuit breaker , heater , wiring
Cadet wall heater Jack E HVAC 1 04-21-2010 04:55 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Venting med. efficiency furnace and H2O heater thru wall? cbrc5eric Building & Construction 2 04-02-2010 11:07 PM
Water heater burst - musty odor in wall! Tiny_J General DIY Discussions 10 02-18-2010 01:27 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
