Wiring Ventilation Fan In Garage/workshop: Can I Use A 3-way Switch Like This? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-25-2008, 08:03 AM   #1
Wiring ventilation fan in garage/workshop: Can I use a 3-way switch like this?
Hi all. I've been reading here for awhile, and learning a lot, but today, I have my first question.
I'm replacing an old, decrepit, dangerously wired gable-mounted exhaust fan that a previous homeowner installed (badly) in my garage.
The new fan I bought, which was designed for attic ventilation, came with a simple 120V electromechanical thermostat. I would like to use this thermostat for automatic operation, but since it would be mounted near the fan, way up out of the way, it will be inconvenient to adjust. Therefore, I'd also like to install a "manual override" switch for when I'm in there working on stuff.
As illustrated below, I've devised a way to use a three-way switch to accomplish this. While I'm confident it will work fine, I'm just wondering if this is an allowable use for a single 3-way switch.
(As you can see, I've also added a main switch, a pilot light for safety, and a speed control.)
Does anybody see any problems? (If so how would you take care of this?)
Thanks!
Wiring ventilation fan in garage/workshop: Can I use a 3-way switch like this?-garage-fan.jpg
thegonagle is offline   Reply With Quote
Old 09-25-2008, 09:10 AM   #2
joed's Avatar
Rewards Points: 12,018
You don't need a three way switch. You could use a regular switch wired across the thermostat(in parallel). That way either the stat or the switch can turn on the fan. Take the black wire you have on the traveller screw and connect it with the black power wire you have on the common screw.
If you want the 3way it will work as you have drawn it.
Old 09-25-2008, 04:12 PM   #3
Thanks.
I figured I could use a single-pole, but I didn't want the on-off markings. The lack of on-off markings is the reason I chose the three-way. I'll label the switch with a label maker as well, but I mostly want a non-confusing setup for whomever might try to use the fan in the future. (Friends, neighbors, future homeowners--you never know.)
Old 09-25-2008, 10:04 PM   #4
What can I find here?
Winchester's Avatar
Rewards Points: 150
Forgive me, but I've never seen a pilot light used in this way before. But according to your schematic, it would appear as though it is wired in parallel. Shouldn't it be wired in series if it's acting like a switch?
Winchester is offline   Reply With Quote
Old 09-25-2008, 10:16 PM   #5
Rewards Points: 506
Send a message via AIM to theatretch85
The "pilot light" in his diagram would light up when the fan has power, whether its set to be "always on" or controlled by the thermostat. Most "pilot lights" light up when the circuit is off to illuminate the switch to be easily found in the dark.
theatretch85 is offline   Reply With Quote
Old 09-25-2008, 10:50 PM   #6
Please forgive the poor terminology.
Yes, I intend for the light to light up when the circuit has power, as a warning that the fan could turn on automatically, and so that I won't forget to turn it off.
I guess a better term would be power light, or indicator light.
Well, I'm off to do the final wiring.
Old 09-25-2008, 11:18 PM   #7
joed's Avatar
Pilot light is the proper term for this. The others a lighted switches not pilot lights. You can actually by switches that have pilot lights.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 06:53 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
3-Way Switch Wiring Question bhpizza Electrical 4 08-07-2007 06:51 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
