Wiring Up A Switch From A GFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 12:14 PM   #1
wiring up a switch from a GFCI
ok so I'm gonna add a switch from a new GFCI that i installed in my bathroom. The GFCI will be giving power to the new switch and to a closet light and plug in the bedroom. This is how it will be
main power->GFCI->new switch->sconces(small lights)
....................'->bedroom(closet light and 1 plug)
I'm in Canada so it is acceptable to have power from the bathroom to the bedroom.
So I'll be using rabbit ears to connect the new switch and bedroom power. This will stop the new switch from controlling the power in the bedroom.
Is this acceptable?
should I or can i do it another way?
Thanks,
Steve
Limit54 is offline   Reply With Quote
Old 01-12-2010, 12:28 PM   #2
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
By the NEC Article 210.12B all habitable rooms must me powered by an AFCI breaker. Since the closet is in a habitable room you cannot tap off the bathroom circuit.
HIVOLT is offline   Reply With Quote
Old 01-12-2010, 12:32 PM   #3
I'm in a 50 year old home and this was how the original wiring was set up(not knob and tub) I have just added a plug(GFCI) in my bathroom where no plug was previously there. This is how it has to be done.
Old 01-12-2010, 12:36 PM   #4
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
Well it is not the right way but it can be done from the bathroon GFI. Make sure you come off the line side of the GFI not the load side.
Old 01-12-2010, 01:05 PM   #5
thanks. So the rabbit ears will be ok from the GFCI?
Old 01-12-2010, 01:10 PM   #6
Rewards Points: 1,442
It's your choice.
1. Run the new cable from the line side hot and line side neutral of your GFCI to your switch box and the new light and receptacles (plugs) will not go dead if the GFCI trips.
2. Run the new cable from the load side hot and load side neutral of the GFCI to your switch box and the new light and receptacles will be under the protection of the GFCI.
Now up in the new switch box run continuation (cables) down to the outlet location and up to the light location.
Old 01-12-2010, 01:11 PM   #7
joed's Avatar
Rewards Points: 11,996
This is Canada. It is fine in Canada.
I don't know what rabbit ears are. I used them for TV reception but to connect a GFCI.
Old 01-12-2010, 01:40 PM   #8
I might have said it wrong..i don't remember the correct term but it is using a single peice of wire that connects from a outlet or switch to connect 2 or more wires together.
anyway regarding Joed's answer. I'm slightely confused now? If I were to connect the line from my new switch box to my closet light and room plug wouldn't the power be cut off to them when my switch is turned in the off position?
Old 01-12-2010, 01:46 PM   #9
Unhappy
Because if you come off the load side, and you use a different Neutral, at any point, it'll trip out the circuit!
spark plug is offline   Reply With Quote
Old 01-12-2010, 03:47 PM   #10
ok I'm still confused here?
I was pretty sure that I had right the first time.
The GFCI will have 1 line going to the switch and 1 line going to the closet(lights and plug) these line are coming from teh GFCI
then the switch going to the new lights.
Old 01-12-2010, 08:15 PM   #11
Question
Limit 54 (Poster # 10) Your diagram only shows that the wiring comes off the GFCI receptacle. But there is a stipulation (As S.P. and others have pointed out) That the wiring for all other circuits must come out of the LINE SIDE of the GFCI receptacle. Then it is the same as any other junction box. (No matter what) Don't Drink and Drive, Ever!!!
Old 02-03-2010, 02:53 PM   #12
Rewards Points: 79
Ah, THAT'S why when I ran my bathroom fan switch off my GFCI load side it kept tripping! It's on a different neutra. Worked fine when I pigtailed it off the line side so I switched it to that.
thebigsee is offline   Reply With Quote
Old 02-03-2010, 02:54 PM   #13
Rewards Points: 79
You've got the right idea, just the wrong animal . . . it's "pigtail", not "rabbit ears".
Old 02-03-2010, 03:42 PM   #14
joed's Avatar
You still have a problem . You can not share neutrals from different circuits or did you mean a different neutral from the same circuit.
Old 02-03-2010, 05:00 PM   #15
Rewards Points: 79
That's a good question. I'll have to examine it when I get home. My house was previously owned and renovated by a licensed electrician (about 10 years ago), so I have always assumed everything was done correctly.
The way the ceiling fan is wired now is: hot wire coming from GFCI Line to switch, from switch up to ceiling fan (albeit via a very LONG route that took me 30 minutes of searching in the attic to figure out). There's no neutral coming back to the switch, but there's a mess of neutrals in the box that as memory serves are pigtailed into the GFCI. One of those neutrals must be from the ceiling fan, but I can't say for sure.
At any rate, that's how it's been for 10 years and I've never had a problem -- I hope it's safe!
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
New wiring and switch for bathroom exhaust fan looking4help75 Electrical 9 06-27-2008 05:15 PM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
