Wiring Up An Overhead Flourescent Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 05:46 AM   #1
Lost..
Rewards Points: 336
Wiring up an overhead flourescent light fixture
I bought two light fixtures to go in my shop last night, but I'm not sure if they will work. The fixtures I bought have a physical receptacle plug coming out of them and are designed to be plugged in to a wall outlet. I don't know if they will work the way I was going to have the wiring done in my shop.
Here is a picture-
I don't know if I can just cut the plug heads off of the cords and they wire the romex directly to that using wire nuts, or if I have to open up the fixture to expose the bare wires, and the romex go in and wire nut there.
I know I could just replace my light box I have overhead with a receptacle box and stick a GFCI (has to be because it is a shop) in there to plug them in to, but I would rather not spend more money on another GFCI. I want to be able to direct wire the light fixture to the circuit.
J S Machine is offline   Reply With Quote
Old 06-03-2011, 05:56 AM   #2
Licensed electrician
Rewards Points: 1,456
Cutting the plugs off would violate the UL listing. You can buy direct wire lights.
Old 06-03-2011, 05:58 AM   #3
Lost..
Rewards Points: 336
Is there any way to just open the fixtures up to expose the wires on the inside and wire to those or do I need to take these back and get different direct wire ones?
Old 06-03-2011, 07:25 AM   #4
joed's Avatar
Rewards Points: 12,332
Put a receptacle in the junction box on the ceiling and plug them in.
Old 06-03-2011, 09:03 AM   #5
Rewards Points: 1,016
I have several similar lights in my garage/workshop - I installed recepts at the ceiing and just plugged them in. Simple, and allows for easy changes down the road. It can be handy to have recepts on the ceiling. I also have reeled drops lights and other lights plugged into the outlets.
Old 06-03-2011, 09:19 AM   #6
Lost..
Rewards Points: 336
I don't want a plug. Should I just go back and get a direct wire fixture, or can I open this one up to run the circuit inside?
Old 06-03-2011, 09:27 AM   #7
Rewards Points: 6,652
Easier having the plug. Stick with simple, don't try to make it harder, especially in a garage.
Old 06-03-2011, 09:40 AM   #8
Just call me Andrew
Rewards Points: 1,020
Get a new one.
Andrew
secutanudu is offline   Reply With Quote
Old 06-03-2011, 10:10 AM   #9
Lost..
Rewards Points: 336
Jim, this is your quote from another thread:
"Under the 2008 or later all receptacles in a garage require GFI protection, including the garage door opener receptacle. The GFI must be readily accessible so ceiling mounted is out."
My ceilings are 9 feet high, so I will not be able to reach them.
Does this mean that I will have to put in direct wire lights?
If I have to have GFCI throughout the shop, and a plug would be an option for these particular lights, I can't do that because it isn't accesible..correct?
Old 06-03-2011, 10:43 AM   #10
That means that you must be able to reach the reset buttons without a ladder. The GFI protection can be mounted on the wall for the ceiling receptacles.
gregzoll (06-03-2011)
Old 06-03-2011, 11:01 AM   #11
That is how mine is wired, but my ceiling is only about 7' from the floor for the lights.
Old 06-03-2011, 12:47 PM   #12
joed's Avatar
Well you didn't tell us it was a garage. All you said was shop. If you want to direct wire them then you need to bring them back and get the correct fixtures.
You could still plug them into a receptacle. If there is another receptacle on the same circuit that one could be the GFCI and protect the entire circuit.
Old 06-03-2011, 12:55 PM   #13
Lost..
Rewards Points: 336
Just curious, what would be the difference between a garage or shop as far as code?
This is a small shop I'm building behind my house. it is big enough to be used for a garage, but that is not it's intended purpose. It will mainly be a storage / work shop.
Old 06-03-2011, 04:00 PM   #14
Nothing, they both fall under the same codes, but for fire codes they could be different in your area.
Mercury Vapor Light Fixture Wiring Hoppy084 Electrical 4 06-24-2010 11:38 PM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 08:54 AM
Wiring of bare copper wire in a light fixture Fleet_Foxes Electrical 5 07-16-2009 08:44 PM
Wiring my light fixture..... yummy mummy Electrical 9 07-15-2009 03:06 PM
I can feel buzzing or "charged" air around a light fixture? jabrockson Electrical 10 03-26-2009 08:20 PM
