Old 05-14-2008, 12:39 AM   #1
Wiring up the living room ??
I have a question about tapping off an outlet circuit. The circuit is 5 recepticals, I want to tap off the end receptical to feed 2 recessed lights. One of the five recepticals is for the LCD Tv. Would I get line interference on the LCD from the recessed lights using those pigtail fluroescents. Or will this be Ok. By tapping off the outlet circuit I am saving about 40 feet of wire.
James Con is offline   Reply With Quote
Old 05-14-2008, 09:57 AM   #2
joed's Avatar
It is very hard to predict interference. The only answer I could give is maybe.
Old 05-14-2008, 10:11 AM   #3
Is tapping off a receptical circuit to feed a couple of oddball recessed lights a practice that is done? Or should I just eat the 40 feet of wire and keep all the lights on the lighting circuits.
Old 05-14-2008, 10:24 AM   #4
Licensed Electrician
jrclen's Avatar
Sure, that is commonly done. I see no problem with your doing this. Watch your wire size, 12 for a 20A and 14 for a 15A circuit. I doubt very much that you will see any interference on the circuit from the fluorescent lamps. I have seen problems with fluorescent lamps in certain recessed fixtures.
John
jrclen is offline   Reply With Quote
Old 05-14-2008, 07:27 PM   #5
It's all 12 /2, -20amp. The circuit is deff not overloaded, I only have the five recept. and two recessed light fixtures. Thanks guys, I will opt to save wire. Especially the price of wire these days.
Smoke detector - Living room with FP and fan ><(((jan(((D> Safety 42 12-28-2007 09:59 AM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 06:34 PM
ideea on how to decorate living room MonicaLove Interior Decorating 3 09-25-2007 02:03 PM
Raising step down living room questions phil. Building & Construction 8 08-29-2007 09:49 AM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 04:33 PM
