Wiring Up A Dishwasher And Disposal - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 06:06 PM   #16
Engineer
Rewards Points: 161
Originally Posted by sublime2 View Post
I'm not saying put both on one line.
Why can you not put anything else (receptacle) on the line.
Why dedicated?
You didn't, but the OP did. It used to be common that the disposal was on the same circuit as receptacles (at least in Chicago.) That's the way every house I've lived in was wired (even the 15 year old house I live in now.) My wife has literally fed everything known to man through our disposal. I'm probably going to install a monster disposal next year, and will probably need to install that dedicated 20A circuit as well.
Would having a disposal on the same circuit as receptacles be a big deal for most folks, probably not. I know a few folks that have a microwave on their countertop though. This could be problematic if the microwave and disposal were on at the same time.
diystephen is offline   Reply With Quote
Old 02-12-2013, 06:17 PM   #17
Why dedicated?
The presence of the receptacle or any other outlets opens the opportunity for something else, like a toaster oven, microwave, coffee maker, food processor, vacuum cleaner, etc... to be plugged in and potentially overload the circuit. You may think you won't do that, but someone else including subsequent homeowners may.
There are very specific codes for kitchens.
sixspeed is offline   Reply With Quote
Old 02-12-2013, 06:25 PM   #18
On the other hand, I haven't seen anything addressing whether connecting an instant hot water dispenser to the disposal circuit is not acceptable.
Old 02-12-2013, 06:30 PM   #19
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I believe most, if not all, dishwashers and disposals will say in their specs to run a separate circuit or share with each other.
There is no specific code saying disposals and dishwashers have to be on their own circuit. In fact, you according to the NEC, you could put lighting on those circuits.
Old 02-12-2013, 06:40 PM   #20
Other than overloading a common DW/DP circuit, I can't think of any other functional reason for dedicated lines, except perhaps the dishwasher has fancy microprocessor electronics and will choke on the transients if you throw some bones to grind in the disposal...
Old 02-12-2013, 06:41 PM   #21
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
That's also my experience. I think this will also be something you will have to consider if your thinking about supplying other equipment or receptacles which is what the French Electrician was refering to ....
(2) Utilization Equipment Fastened in Place.
The total rating of utilization equipment fastened in place, other than
luminaires, shall not exceed 50 percent of the branch circuit
ampere rating where lighting units, cord-and-plugconnected
utilization equipment not fastened in place, or
both, are also supplied.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
frenchelectrican (02-12-2013)
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 10:45 AM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 05:19 PM
Dishwasher wiring tcarter Electrical 5 10-04-2011 09:47 AM
dishwasher, disposal and OTR Micro circuits rasz Electrical 29 08-24-2011 07:47 PM
