Wiring Up A Dishwasher And Disposal - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 11:38 PM   #1
Rewards Points: 29
Wiring up a dishwasher and disposal
I'm renovating my kitchen, and on the permit, the building official notes that the dishwasher and food disposal unit
"must be on two separate circuits of 20A each"
Does the code allow me to hook up any other recepticles on the same circuit as the appliance as long as the two appliances are not together on the same circuit? Or does "separate" really mean "dedicated"? 20A dedicated for each appliance sounds like overkill and I'd like to put more recepticles on those circuits as I'm quickly using up space in the breaker box.
I know I could go down to city hall and ask them personally but that's a hassle and just thought I'd ask you guys if this is a code requirement. What is commonly done in this situation?
Thanks!
lmorsino is offline   Reply With Quote
Old 02-11-2013, 11:52 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
From what the inspector is saying, you need to install a separate 20A circuit for each appliance.
This is not a NEC requirement. This would be a local amendment to the NEC.
Old 02-12-2013, 12:41 AM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Sometimes you can run them on a MWBC- "Multi Wire Branch Circuit". You run 12-3 on a double pole breaker and split the neutral at the junction. I kinda like this since you have to turn both off to work on one of the other. They are piped together and I like doing it that way.
Of course you should check with the local inspector to see what he thinks.
You could also ask if that is a local code amendment or NEC requirement.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-12-2013, 02:28 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Thanks!
I know it used to be allowed on MWBC ( mulitwire branch circuit ) however a nice gotcha this part useally get quite few peoples off guard on this part is.,
A) either appalince shall not have more than 50% of circuit rating which it mean it can not be more than 7.5 amp on 15 amp circuit or 10 amp on 20 amp circuit.
B) I do not know what your local code may required a GFCI for garbage dispoal unit so that is kinda toss up on that part only your inspector will know the details.
And more and more dishwasher and garbage dispoal unit is getting more powerfull so the amp rating do creep up so a new good quality dishwasher can hit high as 12 amp so that will kill the deal with MWBC so that one reason why it have to be it own circuit ditto with garbage dispoal unit.
Now the other reason why I say seperated circuit due some of the dishwasher I know in state side can be cord et plug attachment or hard wired but the key issue is disconnecting means with cord and plug attachment that is not a issue when you work on the dishwasher all you have to do is unplug it. but hard wired verison you will need a lock out tab to keep prevent from the breaker being turn on.
The reason why lock out on the breaker due it is not in sight of breaker box.
Hope that help you with this part.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
NJMarine (02-12-2013)
Old 02-12-2013, 02:41 AM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Separate lines but not dedicated.
sublime2 is offline   Reply With Quote
Old 02-12-2013, 09:23 AM   #6
k_buz's Avatar
Read the OP. his inspection department is requiring separate 20 A dedicated circuits.
Old 02-12-2013, 12:00 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Thanks!
The NEC uses the term 'individual' branch circuit for dedicated or separate. As K Buz has mentioned you need a 20 amp branch circuit to each appliance .. nothing else can be on those circuits. It has become the norm in most areas of the country AFAIK.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-12-2013, 01:08 PM   #8
Rewards Points: 29
Wow, thanks for all the helpful responses, gentlemen...I guess I will just wire it with two dedicated 20A circuits
Old 02-12-2013, 01:25 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
What is the reasoning/thinking behind these appliances being on their own dedicated circuit?
Old 02-12-2013, 03:09 PM   #10
Engineer
Rewards Points: 161
The potential amperage that they might draw.
diystephen is offline   Reply With Quote
Old 02-12-2013, 03:18 PM   #11
Rewards Points: 29
If we're just talking about the "potential" amps they might draw, isn't that what circuit breakers are for? What is wrong with simply adding up the power needs of the two appliances and providing a circuit that can handle that much power?
Let's say the disposal draws 10A and the diswasher is rated at 8.5A. Why is a single 20A circuit not sufficient?
Old 02-12-2013, 03:25 PM   #12
Engineer
Rewards Points: 161
Because there are dishwashers and disposals that draw more than that. Disposals also draw more amperage when people (like my wife) shove too much crap in them Circuit breakers aren't meant to be repeatedly tripped. This will also heat up the wiring, and can potentially damage it.
Then there's the fact that the inspector "said so."
Old 02-12-2013, 03:28 PM   #13
Rewards Points: 29
So the real reason is to provide yet another layer of redundancy for people who don't understand how electricity works. At the expense of everyone else.
Old 02-12-2013, 03:34 PM   #14
Engineer
Rewards Points: 161
Electricity is theory; nobody really "knows" how it works
Even those that have a good understanding of electricity wouldn't want a single 20A circuit for a dishwasher and disposal.
Old 02-12-2013, 06:55 PM   #15
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
I'm not saying put both on one line.
Why can you not put anything else (receptacle) on the line.
Why dedicated?
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 11:45 AM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 06:19 PM
Dishwasher wiring tcarter Electrical 5 10-04-2011 10:47 AM
dishwasher, disposal and OTR Micro circuits rasz Electrical 29 08-24-2011 08:47 PM
