Wiring Underground. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2009, 05:56 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
wiring underground.
I have rewired my house and my shop, but have never run any underground wire. A book I bought says to run it without conduit. A local electrician says to use conduit. It'll be about 25 ft. No vehicles will go over the area. I bought outdoor wire, rated to be buried. I would like another opinion.
Old 07-08-2009, 06:04 PM   #2
300zx's Avatar
Post
If it's Direct Burial Wire 2 ft deep it will be fine.Pipe is good if you ever have a problem you can just pull in another wire.
300zx is offline   Reply With Quote
Old 07-08-2009, 06:08 PM   #3
I NEVER use direct burial cable but it's legal if it's 18" deep.
I've seen some in service for 50 years with no problems.
Electricians don't like it because we like access for repairs. Conduit protects the wiring and allows us to pull new wires if somthing goes wrong.
Gophers don't generally chew thru conduit.
220/221 is offline   Reply With Quote
Old 07-08-2009, 06:14 PM   #4
What will the circuit be used for & where will the wire be run?
If GFCI protected before it goes into the trench then you can go to 12" for a 20a circuit
I do conduit also - just better IMO
Old 07-08-2009, 07:57 PM   #5
Rewards Points: 12
It has to be 18" deep, even if it is in conduit? Or 12" deep? . 20 amp circuit to a garage.
Old 07-08-2009, 08:04 PM   #6
Will this be the only circuit run to the garage?
If you need more then one circuit then you are better of (required?) with a small panel - or a MWBC
!2" deep if GFCI protected before it goes into the ground - without conduit
It must still be protected by conduit where it enters & leaves the trench
Underground wiring job while landscaping tjfitzgerald Electrical 24 03-20-2009 08:22 PM
Outbuilding wiring and underground wiring questions tpagel Electrical 7 07-08-2008 09:38 AM
Running Underground wiring to shop 200Ft kola Electrical 5 06-06-2008 10:13 AM
Underground Wiring millipede Electrical 4 11-24-2006 11:00 PM
'Underground Wiring And Code. michaeltz Electrical 16 12-05-2005 08:58 AM
