I have rewired my house and my shop, but have never run any underground wire. A book I bought says to run it without conduit. A local electrician says to use conduit. It'll be about 25 ft. No vehicles will go over the area. I bought outdoor wire, rated to be buried. I would like another opinion.
What will the circuit be used for & where will the wire be run?
If GFCI protected before it goes into the trench then you can go to 12" for a 20a circuit
I do conduit also - just better IMO
Will this be the only circuit run to the garage?
If you need more then one circuit then you are better of (required?) with a small panel - or a MWBC
!2" deep if GFCI protected before it goes into the ground - without conduit
It must still be protected by conduit where it enters & leaves the trench
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
