Wiring For Undercabinet Lighting With Walls Open - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2009, 06:15 PM   #1
Rewards Points: 12
wiring for undercabinet lighting with walls open
I've been googling for a while and not finding much useful information, everythign I find seems to be for adding in undercabinet lighting to a finished kitchen.
I have my walls totally open and would like to add two sets of undercabinet lighting, one for each side of the room (galley kitchen layout).
I'd like each set controlled by it's own switch (one switch by sink and other switch by stove).
Each side of the room has a "gap" in the cabinets so wiring will have to be in wall. (One gap is the sink and the other gap is the stove)
Could someone explain to me how and where to run the wiring? I obviously will run 14/2 to each switch, but from there should i run 14/2 to a junction box on each side which will be behind the cabinets and then run 14/2 to each section of undercabinet that will be controlled by that switch and just leave the wire sticking out of the wall at the height of the bottom of the cabinet for my rough inspection?
would love any help!
ahreno is offline   Reply With Quote
Old 03-28-2009, 07:15 PM   #2
Licensed Pro
A lot depends on what type of lights you want to use. I usually recommend the self contained low voltage individual fixtures. That way you can wire them daisy chained (wires in/wires out). Just leave the 14/2 sticking out of the wall at about the right height at about the center of the cabinet. Leave at least 18" of free wire sticking out of the wall.
Old 03-28-2009, 07:16 PM   #3
Love for Construction
<*(((><'s Avatar
1) Get the wire that feeds the lights into the switch box
2) If all lights are on the same circuit (controlled by the same switch) you only need one continuous wire (at rough) for the lights
3) The continuous wire runs from the switch, behind sheetrock, through the studs. When you get to a location for an under-counter light, pull a section of wire out at that location and continue to the next light location and do the same.
4) When you are finished with the rough it should look like this: wire will be pulled to feed the lights into the switch box, then there should be at every light location a looped section of wire about 8" long. This looped section of wire will be cut in half outside the wall at time of finish when you need a wire to feed the 1st light and the other half of the wire continues the leg of the circuit to the next light. At the end of the circuit you should have the end of the continuous wire, this will be the end of the circuit so you won't have a wire going out of the last light.
It depends on what type of light you are installing as to how to connect the wire to the light to meet code. The lights we used in california in a track home were low profile fluorescent tube lights, the wire was used was standard romex that was fed through a knockout in the back of the light with a romex connector in the knockout, the lights sat flush to the wall.
Does this make sense.
<*(((>< is offline   Reply With Quote
Old 03-28-2009, 10:56 PM   #4
Rewards Points: 1,016
switched outlet
I put a switched outlet in the cabinet above the microwave/hood - there I put the transformer for the undercabinet lights and ran from there a low voltage wire to each countertop section to power low voltage lights.
I would recommend to look into LED lights - you can get them as puck lights or in strips.
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 08:35 AM
Moisture on walls chrisr Building & Construction 1 01-20-2008 09:37 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 02:55 PM
wiring for recessed lighting krw3153 Electrical 1 10-04-2005 01:39 PM
