Wiring Under Cabinet Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2015, 10:22 AM   #1
Rewards Points: 674
We are remodeling our kitchen and I am down to the studs and ready to do the wiring. We plan on having switched LED under cabinet lighting similar to this:
http://www.homedepot.com/p/Juno-18-i...8-WH/203165895
No LED strips, no pucks. Transformer is built in.
My question is how exactly do you wire this? How does the wire exit the wall? Does it just come out of the wall through the drywall and through the bottom lip of the cabinet like this:
https://images.search.yahoo.com/imag...hspart=mozilla
I have the specs and know the cabinet dimensions, but how do I hit it exactly like that? How big of a hole do you leave in the drywall? I don't want to do this and be an inch too low and see the drywall hole below the cabinet. I am probably overthinking this but any advice would be great.
B
Beepster is offline   Reply With Quote
Old 08-19-2015, 11:28 AM   #2
Licensed electrician
Rewards Points: 1,756
That second picture is exactly how I rough in for hardwired undercabinet lights. Staple the cable an inch or two higher than the bottom lip. Once you have the exact level, slot the hole in the drywall lower.
Old 08-19-2015, 12:19 PM   #3
Rewards Points: 674
When you put the drywall up, how big of a hole do you leave in the drywall for the wire to stick out of? I realize that hole can be increased when the cabinets are installed if it is too high.
B
Old 08-19-2015, 12:30 PM   #4
Just enough for the cable.
Wiring old medicine cabinet with fluorescent lighting okieopie Electrical 9 05-11-2015 08:51 AM
Under cabinet lighting usmc0302 Remodeling 13 08-12-2012 05:18 PM
Rough in for under cabinet lighting Lattimer Electrical 5 01-23-2012 04:32 PM
Another cabinet lighting question bcbud3 Electrical 0 10-25-2010 11:35 PM
LED Under Cabinet Lighting Kstrats Electrical 2 07-28-2009 12:49 PM
