-   -   Wiring for under cabinet lighting (http://www.diychatroom.com/f18/wiring-under-cabinet-lighting-147133/)
fredm54 06-15-2012 01:07 PM
I've been trying to decide between line voltage Xenon under cabinet lighting or low voltage Led strip lighting. I am planning to pull a separate 14-2 romex to the upper cabinet above the range. The over the range microwave will be on a separate circuit. If I went with Led lighting I would have to mount a LED driver (power supply) in the over the range cabinet and from there run 12 volts wiring to the LED strips.
The Xenon lighting would be cheaper and probably better dimming performance than LED lighting plus I don't loose cabinet space to mount the power supply.
Also, all the cabinets will be on a concrete block wall that has furring strips and 1/2" drywall and it's a 2 story house so there's no access there once the ceiling goes up.
So is it ok to run a lamp cord wire inside and underneath the cabinets for the line voltage xenon lights?
thanks!
Evstarr 06-15-2012 01:09 PM
No! It's not.
rjniles 06-15-2012 02:29 PM
Originally Posted by Evstarr (Post 944019)
No! It's not.
Why not, it is in/under the cabinet and is accessible. That is the way those lights are intended to be wired.
fredm54 06-15-2012 02:46 PM
Just to clarify some more, the wire will not be in the wall, it will either be underneath the cabinets or inside some cabinets so I can get to the other side of the range.
thanks!
Evstarr 06-15-2012 02:50 PM
How would you ground the fixture using zip cord?
fredm54 06-15-2012 03:14 PM
Good question but I bought a set of 3 Xenon puck lights at home depot to test and each puck has a 4' lamp cord with a 2 prong plug at the end! :confused1:
stickboy1375 06-15-2012 04:51 PM
12 Attachment(s)
Don't install puck lights... they are horrible... got with something like these if you want a quality UC fixture...
http://www.nslusa.com/xenontask.html
http://www.nslusa.com/images/NSL_Cop..._task_app1.jpg
rjniles 06-15-2012 05:28 PM
Those fixtures that come with a 2 wire cord do not have to be grounded. Fixtures that are hard wired need to be grounded.
stickboy1375 06-15-2012 05:29 PM
12 Attachment(s)
they are no different than a two wire table lamp...
Evstarr 06-15-2012 07:03 PM
You and rjniles are, of course, absolutely correct! In my defense, I simply did not assume prewired puck lights when I thought about installing under cabinet lights.
I will drink more coffee and not answer from the car on my phone in the mornings any more!
k_buz 06-15-2012 07:10 PM
I am going to say that this would not pass inspection. It seems as if you will be using a flexible cord as permanent wiring which is not legal.
stickboy1375 06-15-2012 07:12 PM
12 Attachment(s)
No way, these are UL listed lights... Not NEC enforceable....
k_buz 06-15-2012 07:17 PM
I was talking about the wiring TO the puck lights, not the leads off the puck lights.
stickboy1375 06-15-2012 07:19 PM
12 Attachment(s)
I must have mis read something, because I thought his intentions were to bring a 14-2 to a cabinet? Im assuming after that fact he was just going to install a duplex and plug the puck lights in?
fredm54 06-16-2012 12:18 PM
1 Attachment(s)
Yes, I was going to run a 14-2 romex into one cabinet but then run zip cord underneath and inside to get to the bottom of the 3 adjacent cabinets.
I'm going to look further into something like what Stickboy suggested.
I could use one or more of the small appliance outlet boxes to use as a junction point for the 14-2 UC lights but those boxes will be crowded.
I uploaded a quick (not to scale) drawing of what will become my kitchen!
The Red and Green symbols are the Small Appliance (SA) outlets. Right now the only outlet box is the green one next to the sink. This is the original builder installed (1983) It has a 12-3 romex for the SA and the dishwasher and disposal (black wire = SA, Red wire for DW and Disposal) This box is staying as is. Its a 4x4 plastic box that's about 2.5" deep. (concrete block wall has a hole knocked in it to allow for the deep box)
I was going to use Raco 185 boxes and surface mount them to the concrete wall which with the furring strip and dryway the box would be flush. These boxes are only 18 cu in but if I have to I'll have to knock 3 more holes so I can go with deeper boxes. This would allow me to run a 14-2 in and out so i can get all the xenons on one circuit. I really don't want to run a seperate 14-2 from the breaker panel to each xenon and use the breaker panel and tie those 4 14-2's to one breaker.
Maybe the simple thing to do is go with low voltage wiring (zip) for LED lighting. If I do that I could run one 14-2 into the microwave outlet box, mount a power supply and run zip cord everywhere (but not behind drywall)
thanks!
