Wiring Two Sheds, Horse Stall - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-20-2012, 10:58 AM   #16
Rewards Points: 79
Your advice has been helpful and I appreciate it. Hopefully a sparky will come along and see this.
BrandonD is offline   Reply With Quote
Old 12-20-2012, 01:49 PM   #17
Semi-Pro Electro-Geek
Rewards Points: 2,990
Originally Posted by tylernt View Post
Also, I think you might need a service disconnect as close as is practicable near the conduit entrance on the second shed? I've heard of a 4-way light switch (each pole switching one leg of the MWBC) being used for this purpose though, so, not expensive.
A double pole switch, but not a 4-way. They look identical but do different things! A 4-way switch would not disconnect power, but just swap the hot legs when you flip it. A simple double pole switch would be fine, and Lowes/HD carries them.
As for GFCI, yes, GFCI is totally compatible with MWBC. You can put GCFI on just one leg or both if you wish. However, after the GCFI, the neutrals need to remain independent. I.e., don't tie the line side and load side neutrals together.
Since he was asking about using a GFCI breaker rather than receptacles, it really doesn't work with a MWBC. Since the neutral downstream of the GFCI cannot be shared, there's now ay to use a single pole GFCI breaker on a MWBC. You can get double pole GFCIs, and those are fine on a MWBC, but they are very expensive. Better to just use GFCI receptacles, unless you need the protection for a shallow-buried UF cable feeder.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 12-20-2012, 01:51 PM   #18
Special User
Rewards Points: 1,230
D'oh, thanks for the correction!
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-20-2012, 05:43 PM   #19
Rewards Points: 79
Thanks mpoulton. Any comments on the wiring diagram in post #8?
Originally Posted by TTW View Post
Love to see a shot of the whole thing!
Is there an info plate on the motor?
Here you go. Not the best of pictures...
http://s1311.beta.photobucket.com/us...%20Table%20Saw
http://s1311.beta.photobucket.com/us...y/Old%20Planer
I found an online community for old wood working machinery. I'm going to post on there to get some advice on cleaning these up before I use them. Will be nice to be able to use these guys but won't get full use of them until the workshop is built!
Old 12-20-2012, 05:59 PM   #20
TTW
TTW's Avatar
If you paste the IMG code from photobucket, the pictures will show here.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-20-2012, 06:01 PM   #21
Rewards Points: 79
I'm aware; but those are links to two albums containing 16 photos. I'd rather not embed 16 slightly off-topic photos in this thread :-)
The Following User Says Thank You to BrandonD For This Useful Post:
TTW (12-20-2012)
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
