Wiring Two Lights With Switch At End Of Run. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2013, 08:03 PM   #1
wiring two lights with switch at end of run.
How to wire two lights with power on one end and the switch at the other end(lights in middle).A picture would help.
Thank you for any help.
jsx1000 is offline   Reply With Quote
Old 05-10-2013, 10:11 AM   #2
Special User
Rewards Points: 1,230
The "best" way is to run 14/3 or 12/3 cable. Black is "always hot" and red is "switched hot". Connect the incoming power feed black to black on your new cable. At the switch, attach black to one terminal and red to the other switch terminal. Connect the lights to red.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 05-10-2013, 03:11 PM   #3
Rewards Points: 512
Originally Posted by jsx1000 View Post
How to wire two lights with power on one end and the switch at the other end(lights in middle). A picture would help.
(lights in middle) This is a bit ambiguous.
  • Are you wanting to control the lights from two different locations?
  • Do you want power to enter one of the lights, continue to other light and, then, go to a single-pole switch?
  • Power to enter one single-pole switch, and, then, go to lights?
Installation is the Reverse of Removal.
Old 05-10-2013, 03:50 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Just because you think the lights are physically in between the switch and feed does not mean that is the best or easiest way to wire them. Either bring the feed to the switch, or bring the feed to one light and drop a switch loop to the switch and another leg to the other light.
You can do it with a 3-wire between the lights but why make it more complicated than it needs to be just because of the physical layout.
The Following User Says Thank You to Speedy Petey For This Useful Post:
sirsparksalot (05-10-2013)
help wiring exhaust fan w 2 lights AND a separate shower light into a 4 switch Taran7 Electrical 2 09-18-2014 06:07 PM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
lighting wiring diagram help, changed fan with lights to fan w/out and recesed lights snowmanZ Electrical 11 02-09-2013 05:38 PM
Help with wiring: 1 switch controlling 2 lights streko Electrical 6 05-02-2012 09:43 PM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 05:04 PM
