Wiring Two Light Switches On The Same Circuit. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2010, 10:46 AM   #1
Rewards Points: 150
Wiring two light switches on the same circuit.
Can I pig tail from my incoming feed into two switches? Please see the poorly drawn attachment.
Thanks.
Abs777 is offline   Reply With Quote
Old 04-22-2010, 10:47 AM   #2
Rewards Points: 150
I just looked at the drawing and realized that my neutral would be passed through to the lights.
Old 04-22-2010, 11:02 AM   #3
Just call me Andrew
Rewards Points: 1,020
You can pigtail to feed two switches like you pictured. The white wire would not be connected to the swith. The 3 whites would be nutted together (source, one going to each light).
The incoming hot would be split and to one screw on each switch. The blacks coming from the lights go to the second screw on each switch. Grounds get tied to everything and connected to the incoming ground.
Andrew
secutanudu is offline   Reply With Quote
wiring a bathroom fan, light, heater combo on two switches zddingus Electrical 9 04-22-2010 08:48 PM
2 switches 2 lights line in through light 1 bldaz Electrical 9 12-24-2009 07:42 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Multiple lights and switches on one circuit Straightgrain Electrical 5 03-31-2009 08:34 AM
add a second light to an existing 3 way switch circuit djohns10 Electrical 6 03-02-2007 08:16 PM
