Wiring Through Light... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-10-2013, 05:35 PM   #16
Rewards Points: 506
Originally Posted by MTN REMODEL LLC View Post
Joe....man I'm learning alot...I'm a GC (semi-retired so not dailey up to date) but we can't black-tape the white anylonger in a switch loop.???? Is that 2011.
Peter,
What I'm seeing, and perhaps what Joed is referring to, are two white wires on the lighting fixture (even though one is reidentified with black tape). I don't know if there's a Code article on this, but I've heard many electricians speak against it. PLUS, I don't think it is necessary to have 2 whites on the lamp.
Installation is the Reverse of Removal.
Old 05-10-2013, 05:37 PM   #17
Rewards Points: 506
Originally Posted by jbfan View Post
You can do either, but new codes require a neutral wire at switch locations.
IMO, it is better to run power to switch 1, 3 wire to switch 2, then 2 wire to light fixture.
It also depends on which Code cycle your locality uses. Here, we don't require a neutral at the switch (2005).
The Following User Says Thank You to sirsparksalot For This Useful Post:
stickboy1375 (05-10-2013)
Old 05-10-2013, 06:48 PM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by tylernt View Post
Correct. Occupancy switches used to use the ground wire for their motion sensing circuitry, but the NEC doesn't like that (they think grounds should only be there for faults). So, the NEC is now providing a neutral so that motion sensors can stop using the ground.
The real issue is the UL has no issue with using the grounding conductor to carry such a small amount of current, and had no plans on changing this, the NEC got upset and came up with requiring a grounded conductor at each switch location... go figure...
Old 05-10-2013, 07:02 PM   #19
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,448
Geez Sticker..... Pretty soon we're gonna have to have a GFI and AFI on our cell phone and flashlight.
Peter
MTN REMODEL LLC is online now   Reply With Quote
Hard Wiring vanity light fixture into outlet? qwiksilvertrav Electrical 16 02-24-2013 02:16 PM
Rerouting Bathroom Wiring roasted Electrical 36 05-13-2012 10:58 PM
confusion with track light stephenbishop Electrical 7 03-10-2012 02:37 PM
trying to figure out Knob & Tube wiring on old light fixture dalethompson Electrical 16 02-02-2012 09:42 PM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
