Old 12-06-2011, 05:48 PM   #1
wiring three switches for a bathroom exhaust fan, light and heater
I want to wire a exhaust fan with heat and a light. Looking for some direction on how to wire switches for each function exhaust fan, light and heat?
jlgs35 is offline   Reply With Quote
Old 12-06-2011, 06:56 PM   #2
joed's Avatar
Power to switch Then four wires + ground to unit. One wire is neutral. Each of the other three wires is power to fan, heater, light.
At switch connect power neutral to unit neutral.
Connect power to three pigtails. Connect one pigtail to each switch. Connect hot wires fro unit to each separate switch.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-06-2011, 09:04 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
You are most likely going to need #12 for the heater, and that would most likely have to be on a separate circuit than the lights. Post the spec's on the unit, which is manufacturer & model #, and pictures of your current switch layout.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 12-06-2011, 09:42 PM   #4
Optional refinement.
Use a 3 way switch for the heater with power connected to the common terminal.
The fan switch is fed from one of the heater switch terminals instead of the power feed. The other heater switch terminal is for the heater.
This way you must have the heater off in order to turn the fan on, thus avoiding wasting heat out the exhaust.
In any event you may need a heavier duty switch (amperes rating) for the heater.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 03:37 PM
Bathroom switch for light exhuast heater finite15 Electrical 6 05-10-2011 09:00 PM
bathroom light with fan and heater abrite98 Electrical 10 11-02-2010 08:03 PM
Wiring for replacing a bathroom fan, heater, light and night light unit. tgallopbs Electrical 24 11-02-2010 10:57 AM
wiring a bathroom fan, light, heater combo on two switches zddingus Electrical 9 04-22-2010 08:48 PM
