Wiring Three Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2011, 10:01 PM   #1
Wiring three receptacles
I have the project of wiring three receptacles on the same circuit. I'm in trade school (community college) and have never done this before so I need some sort of lead. The thing I have to do is wire receptacle #1 to receptacle #2 then receptacle #3 back to #2 then wire It into the circuit breaker. I have no clue on how to go about this. I've posted on ET and got no help but referred here.
Ideal Fan is offline   Reply With Quote
Old 02-04-2011, 10:23 PM   #2
waterman1971's Avatar
Rewards Points: 150
What sort of "trade school" are you enrolled in?
waterman1971 is offline   Reply With Quote
Old 02-04-2011, 11:50 PM   #3
Electrical Supplier
Rewards Points: 150
Wire #1 to the posts on #2, then pigtail the remaining posts on #2 into the breaker feed and the line to #3. Wire nut in box #2...
What is causing your confusion......
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 02-06-2011, 02:32 PM   #4
Like this?
Then of course wire it up.
Old 02-06-2011, 04:09 PM   #5
Electrical Supplier
Rewards Points: 150
Yeah, but i think you might need a deep box for that middle one...i forget the capacity of 18 CU In boxes off the top of my head.....Theres a number of wires you can have inside the box......plus a 22 CUin might be easier. But yes, thats how I would do it.
Old 02-06-2011, 04:19 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
If your 18 cu in box has no internal clamps (an internal clamp counts as 1 conductor) you are right at the limit for the box. 6 conductors + 1 ground + one device(= 2 conductors):
6 + 1 + 2 = 9 x 2 cu in (for 14 gauge wire) = 18 cu in.
A better plan is to feed the box from one end and not have 3 cables in a box.
If you use you wiring plan I would us e a larger box for the 3 cables.
Coastal South Carolina
Old 02-06-2011, 04:45 PM   #7
Yeah I'm using all 22.5 in^3 boxes because that's all my teacher has. It has to have all the wires from the other receptacles feed into the middle box then Into the circuit breaker. (his project for different scenarios.)
Old 02-06-2011, 11:30 PM   #8
Electrical Supplier
Rewards Points: 150
Yeah most plastic boxes have the amount of conductors stamped on the back of the box....
You are golden with those 22.5s
trying to get educated about house wiring ChrisJJ Electrical 7 08-08-2010 03:23 PM
Rewiring - adding receptacles, paths to use RST Electrical 2 03-14-2010 03:29 PM
Charred / melted wall receptacle, AL wiring in house creamaster Electrical 17 12-04-2009 05:47 PM
Wiring Receptacles Bocolo Electrical 17 03-02-2009 06:01 PM
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 11:49 AM
