Originally Posted by Jarrod3154
I have a double pole 30 amp breaker in breaker panel for old electric hot water heater. Bought a tankless water heater that calls for 60 amp breaker with # 6 awg. Do I need to put two pole 60 amp breaker and new wire to install or will what I have work from old tank water heater.
What model number of this tankless waterheater and I know pretty good percentage of larger tankless electrique waterheater do use a bit of power typically they will have
two or three 60 amp circuits .,, please note this I say circuits so it will have that many circuit { Canadian unit are wire little diffrent but I will leave it out for now unless you are from that area then I will fill you in }
Second thing DO not use the old 10 gauge wire from tank type water heater to the tankless it is too light for this useage.
You will need to get #6 awg cables { typically 6-2 NM } plus a local disconnect switch if not in sight of breaker box.
Oh yeah just watch out some larger tankless electrique water heaters are hard on service.
Merci.
Marc
