Old 12-14-2011, 09:13 AM   #1
demandrew's Avatar
Wiring switches in Ontario
Hello all, I'm doing some minor electrical work and I wanted your opinion on light switches. I'm thinking here of either having a switch-leg drop from the light or bringing power to the switch first and then to the light. Are both methods considered equal as far as the province of Ontario is concerned? Which method do you prefer and why or does it mostly depend on the distances of wiring that are involved?
demandrew is offline   Reply With Quote
Old 12-14-2011, 09:17 AM   #2
A "Handy Husband"
rjniles's Avatar
I have no knowledge of the CEC requirements but my preferred method is to bring power to the switch box. This gives me a neutral in case I ever want to add a timer or a device requiring a neutral.
Having a neutral in the switch box is also a requirement of the NEC 2011 update.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-14-2011, 02:35 PM   #3
Electrician
You can do either way and it will meet code. I also recommend to bring the power to the switch first, then if you ever need the neutral you have it in the box. If it easier to do switch legs and it is not far it wouldn't hurt to use a piece of 3 wire for your switch loop and then you have a neutral there if you ever need it.
darren is online now   Reply With Quote
Old 12-14-2011, 03:36 PM   #4
In all my years of wiring I never considered which way was important. Code allows either way!
What is more convienient always was the deciding factor for me!
In a home, power can be looped from outlet to outlet and a switch leg dropped as required.
However, its sometimes convenient to retrofit a P&S combination recept/switch if a neutral is available in a switch box.
Guess its 6 of one and half dozen of the other.
Old 12-14-2011, 10:30 PM   #5
demandrew's Avatar
Thank you for your helpful replies. I think I will opt for putting power through the switch first, but it's good to know that both methods are code compliant. I like the idea of having a neutral wire in there for future possibilities, and it will also mean one less wire running up through my ceiling.
multiple light switches on existing basement Wiring fdasilva Electrical 8 05-31-2011 10:30 AM
Ontario Canada Pool Pump Wiring cramar Electrical 1 05-18-2011 05:58 PM
wiring 2 hi/low/limit switches in parallel CowboyAndy HVAC 3 12-11-2008 02:50 PM
wiring switches Dean1234 Electrical 2 11-02-2008 12:46 AM
wiring two switches and two fans rtyui2 Electrical 1 11-22-2007 05:32 PM
