Wiring Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2008, 10:57 PM   #1
wiring switches
I am wiring two adjacent rooms for lights, is there anyway to pull power from the last light fixture in one room, to a switch in the second room to control those lights? I am thinking not and will have to run another wire to the original switch and pigtal it but I thought i would see if anyone had others ways.
Dean1234 is offline   Reply With Quote
Old 11-01-2008, 11:41 PM   #2
Not really, unless the fixture is fed by a 3 wire cable it is not possible.
Because the last fixture most likely has a switched hot and a neutral. You need a live hot, switched hot and a neutral for it to work.
rgsgww is offline   Reply With Quote
Old 11-01-2008, 11:46 PM   #3
You are probably correct but there is a chance.
First step. Remove the switch and see how many wires there are in the box. If there are two wires, you will have power at at least one of your existing light j boxes.
220/221 is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Wiring diagram for lights with two switches Ed M Electrical 7 08-10-2008 08:59 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
wiring two switches and two fans rtyui2 Electrical 1 11-22-2007 04:32 PM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 01:42 AM
