Wiring Switched Outlet
Currently I have 2 outlets, both controlled by separate switches. Switch 1 has a red, white, and black wire, controlling outlet 1, which has 2 white and 2 black wires. Switch 2 also has a red, white, and black wire, controlling outlet 2, and outlet 2 has one white and one black wire.
I'd like to have the bottom half of each outlet always hot, and top half work with the switch. Is there any way to do this without running new wire? |
DO both switches control both outlets together?
Are there any other wires in the outlet boxes that are not connected to the actual outlets? How about other wires in the switch boxes that are not connected to the switches? |
are the outlets controlled by more than 1 switch? for 1 switch to control 1 outlet it would only need 2 connections on it. it sounds like you have 2 3-way switches controlling both outlets. could this be the case?
Nope, the switches and outlets are totally independent. At least that's the way they tested. There are no extra or free wires in any of the boxes.
to split the outlet and switch one half and have the other half hot all the time you need 3 wires- 2 hot ones and a neutral with one of the hot ones switched. so to do what you want you would have to run more wire.
That's what I figured. It just seems odd there's a red wire but nothing is switched. If I want to disable the switch and make the outlets always hot, would I connect the red and black together or black and white?
did the switches have 3 wires connected to them?
If the switches have the 3 wires connected, then they are 3 way switches. To verify, the switch toggles will not be marked on/off.
If the red wires do not appear in the receptacle boxes then there are other switch boxes somewhere. |
Any tips on what wires to connect to bypass the switch?
You have another box somewhere, either another switched receptacle or a blanked-off box... maybe behind some furniture? Until you find that and determine how things are wired, I won't want to "guess" as to which wires should be connected.
The only place I see a red wire is on the 3 way switch and the other 3 way across the room. |
I checked the basement and didn't see anything. I did see the wiring for the outlet I wanted to make switched though. I may splice into another nearby line and just make the bottom outlet hot all the time. What's the best/safest wire to use? 14/2 and not use the other connections in it?
| All times are GMT -4. The time now is 02:13 PM. |
