Old 09-11-2012, 12:14 PM   #1
Wiring switch/recept/light switch help
Hey guys - need some help. I had this all figured out when I ran the wires, but can't make sense of it now 3 months later...can someone run through how I need to configure this so it all works??
Many thanks
Wiring switch/recept/light switch help-wiring.jpg
MLayden is offline   Reply With Quote
Old 09-11-2012, 09:26 PM   #2
Many thanks
Attachment 57224
How do you want it to work? Everything hot all the time? Everything switched? Can I assume the receptacles are to be hot all the time and the light switched? Why do you have a 3 wire going to the light?
parman is offline   Reply With Quote
Old 09-11-2012, 11:11 PM   #3
Sorry. Looked again - have 14-2 going to the light from the recept.
Want the recepts hot and the light on switch.
Old 09-11-2012, 11:31 PM   #4
Master Electrician
Switch box
Wirenut the red from the 14/3 and a pigtail to the incomming power. Tie pigtail to switch. Tie black from 14/3 to other side of switch. Wirenut neutrals.
First receptacle.
Wirenut The black from the 3 wire to the black going to the light. Wire the red from the 3 wire to the receptacle. Wire the black from the second receptacle to the receptacle. Wirenut neutrals and hook to receptacle as required.
Second receptacle and light.
Wire as per black to hot white to neutral.
Remember to tie in grounds as needed.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
MLayden (09-12-2012)
Old 09-12-2012, 12:59 AM   #5
Thanks everyone. Had it the way Andrew said, but one of my neutrals came loose...went back and made sure everything was all tight and good to go.
Thanks again.
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 11:26 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 09:49 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
