Wiring Switch To Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 01:14 PM   #1
wiring switch to outlet
ok i want to put and outside outlet on my enclosed deck. i want to run a switch to it so i can just flip switch and outlet works. this will be helpful as i have a coup with ginny hens in it and when its cold i want to turn the heat lamps on. i can leave extension cord plugged in and then just flip switch to turn on/off.
so is this right?
source (12/2) to switch
12/2 from switch to outlet
is it just that simple??
thanks for looking
Kansas is offline   Reply With Quote
Old 03-03-2013, 01:16 PM   #2
eastcoastsparky's Avatar
Rewards Points: 150
Yup thats it
eastcoastsparky is offline   Reply With Quote
The Following User Says Thank You to eastcoastsparky For This Useful Post:
Kansas (03-03-2013)
Old 03-03-2013, 01:37 PM   #3
Electrical Enthusiast
Rewards Points: 504
You got it. Make sure you wire the switch with the black (hot wires), and pigtail the neutrals together.
Also make sure at the outlet you wire the black to brass screws and white to silver screws.
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
Kansas (03-03-2013)
Old 03-03-2013, 02:18 PM   #4
Thanks everyone!
Old 03-03-2013, 03:15 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
An use a GFCI receptacle.
Coastal South Carolina
Old 03-05-2013, 08:57 AM   #6
Rewards Points: 2,516
An make sure it is a weather resistant(WR) GFCI. Make sure it does not have this sticker on it.
hammerlane is offline   Reply With Quote
Old 03-05-2013, 10:23 AM   #7
I'll check but I'm moving existing outlet on my deck to now outside newly enclosed deck., but I'll check, thanks!
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
Help wiring a ceiling fan from a half hot outlet controlled by a switch harleydadokc Electrical 3 06-15-2012 12:06 AM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
