Wiring Surprise - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2008, 06:53 PM   #1
Rewards Points: 334
Question
Wiring surprise
I have a small HVAC duct in my utility room and I opened up the vent only to find an electrical wire running thru the duct (it actually is coming from the panel). This is an older home (early 60's). My question is, is this OK? And is this up to code?
tripower is offline   Reply With Quote
Old 10-10-2008, 07:29 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
It’s not surprising to find your situation in older homes like yours. I don’t know what the code was back in the ‘60’s, but today it wouldn’t be allowed unless the cable was plenum rated. Common cables used today for houses aren’t plenum rated.
You can remove the cable and re-route it around the ductwork, using junction box(es) and appropriate fittings if necessary.
Kyle
Old 10-10-2008, 07:45 PM   #3
Rewards Points: 334
Originally Posted by SD515 View Post
Itís not surprising to find your situation in older homes like yours. I donít know what the code was back in the Ď60ís, but today it wouldnít be allowed unless the cable was plenum rated. Common cables used today for houses arenít plenum rated.
OK, thanks.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 04:56 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
