Wiring Subpanel Wire Too Short - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 11:28 AM   #1
wiring subpanel wire too short
I am wiring a subpanel in my garage. I needed a run of 85' of #6 wire for my 60 amp panel. However when I got the wire and it is only 75'. I can't complain since I got the wire for free...but the issue it I'm still 10' short. I can go buy 4 more runs of #6. But I am at a loss as to how I can connect these wires together. I have heard I need to out it in a j-box. But I have heard and read many different ways of joining the wire together. I have heard butt connectors, wire nuts, soldering and even putting in a box with 4 poles in it. Needless to say I'm confused and would like to ultimately get it to pass inspection.
So my questions are...will an 85' run of wire with a junction in it pass inspection for a subpanel? What kind of j-box do I need (size, metal vs plastic), what should I use to join the wire (wire nuts, butt connectors, etc), how do I wrap these wires when I put them together (insulated tape, rubber tape, electrical tape), and finally I am running 4 #6 thhn through 1" Pvc 90c conduit, can I use #8 or #10 as ground so I don't have to go buy more #6 since I can get #8 and #10 for free.
Thanks for all of your help and if u have any questions please let me know.
kenmore is offline   Reply With Quote
Old 06-02-2011, 11:45 AM   #2
Rewards Points: 6,652
No it will not pass. I would get the length you need.
Old 06-02-2011, 11:46 AM   #3
Sparky
Rewards Points: 510
you dont need a #6 for ground, use the 4th piece to make your extensions and pull a #10 ground
a 6x6 pvc box should be plenty big
you can splice 2 #6's with a big blue wirenut similar to #454 here (Orange and Blue both sell these) http://www.idealindustries.com/produ...n/wing-nut.jsp
Techy is offline   Reply With Quote
Old 06-02-2011, 12:02 PM   #4
What would be better to join the #6 wires a wire nut or split bolt?
Old 06-02-2011, 12:05 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Why not?
The Following User Says Thank You to jbfan For This Useful Post:
SD515 (06-02-2011)
Old 06-02-2011, 12:11 PM   #6
Licensed electrician
Rewards Points: 1,294
Wire nuts are much cheaper and easier than a split bolt.
Old 06-02-2011, 03:32 PM   #7
Rewards Points: 1,574
So it is ok to splice the feed in a junction box before the subpanel?
bob22 is offline   Reply With Quote
Old 06-02-2011, 04:32 PM   #8
Missouri Bound's Avatar
Yeah...tell us why not.
Old 06-02-2011, 04:34 PM   #9
jbfan's Avatar
Rewards Points: 254
Yes, as long as you meet the requirements for the jbox(proper size, accessibility)
bob22 (06-02-2011)
My utility room's wiring, before rewiring WillK Electrical 0 01-07-2011 11:44 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
Dimmer wiring in a box with 3 black and 3 white wires and a pink wire to boot! everender Electrical 9 02-15-2009 10:24 AM
Wiring a subpanel bigbassg Electrical 14 07-01-2007 02:53 PM
Can i add a subpanel fed by 10/2 wire? qst4sno Electrical 25 04-25-2007 06:14 AM
