#1 |
Wiring a subpanel using only a 10-2G line feed
I need to replace the entire well pump electrical system as lightning fried everything. I replaced all the components and rewired everything up to the sub panel with a 10-2G with a maximum load of 28 amps. However, my problem is that the line feed coming into the subpanel is underground more than 200 feet away and the meter indicates 240 volts coming in. However I still need to try and add a 110 volt circuit to have a switch for a light and outlet for the sprinkler system to be plugged in. I think I have the wrong sub panel as it is the black plastic GE with 4 circuits as it does not look like I can adapt anything. I wired the outlet and light just like normal, the outlet indicates a open neutral and the light bulb blew. What the heck is wrong, am I missing something? PLEASE HELP!
#2 | |
Licensed Electrical Cont.
Wiring a subpanel using only a 10-2G line feedQuote:
You have NO neutral and CANNOT add a 120v load at this location. You could have installed a panel and gotten both 120v and 240v if you ran 3-wire instead of 2-wire.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#3 | |
Semi-Pro Electro-Geek
#4 | |
" Euro " electrician
I gave the poster the answer from other thread and told them to start a new thread so here part of my answer here.,
Second thing the distance you will have voltage drop issue. Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
#5 |
I did not run the 10-2G line feed, it was what was there and all I have to use and know there is a way to do it without running a new line feed as it was done before, how it was done, I do not know, but I know it is possible.
I have properly wired all the components up to the sub panel, but getting the line feed and load to work together is not happening. It is impossible to run a new line feed and have to use what I have. I also installed a 8' grounding rod too. I am frustrated, please help! |
#6 |
also, is there a simple way to get a neutral feed line to the sub panel (piggy back or steal from another circuit) without going all the way back to the original line feed source? as in from another panel or anything?
#7 |
surprisingly i ran a test on the line and see no voltage loss at all, running a solid 240 volts on the line feed!
#8 |
Licensed electrician
In order to get both 120 and 240 volt circuit you need a xx-3+ground feeder, not xx-2. Sounds like someone was improperly using the grounding conductor as a neutral.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#9 |
You won't see the voltage drop until there is a load on the circuit.
| The Following 2 Users Say Thank You to Jim Port For This Useful Post: | frenchelectrican (01-24-2012), zappa (01-24-2012) |
#10 | |
Merci, Marc
#11 |
Jim that is what I was thinking too. It was all mickey moused and they had wires hanging from the rafters with string, LOL! So that you know what I am dealing with. I have to have the 220 for the pump, but i also need a 110 for the sprinkler controler too!
#12 |
Sounds like time for some rewiring.
#13 |
If it worked before it was VERY illegal and VERY unsafe!
| The Following 3 Users Say Thank You to Speedy Petey For This Useful Post: |
#14 | |
#15 | |
Merci, Marc
| Display Modes | |
| correct garage subpanel wiring | lawsklsux | Electrical | 14 | 11-14-2010 11:54 PM |
| splicing in a subpanel using lines that feed main breakers? | lettcco | Electrical | 7 | 09-11-2010 09:16 AM |
| A few slightly different questions on subpanel wiring. | Chris Dopp | Electrical | 8 | 06-26-2009 10:45 PM |
| wiring help - subpanel? | plunkinberry | Electrical | 2 | 03-12-2009 02:37 PM |
| wiring 50a 220 line | mgarfield | Electrical | 2 | 07-27-2008 11:44 PM |
