Wiring Sub Panel For Pool - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2008, 12:10 PM   #1
wiring sub panel for pool
Hi
I`am a electrician and i`am looking for some professional help with wiring a pool sub panel.
My question is : can i run direct buriel cable to the subpanel.
and do i need to run the #8 solid with the sub feeder. thanks
sparky62 is offline   Reply With Quote
Old 08-30-2008, 12:20 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
No you cannot run cable. Unless it is existing, a feeder to a pool panel must be in conduit ALL the way.
See NEC 680.25
What #8? The bonding grid #8?
No, this has NOTHING to do with panels or grounding.
See ALL of 680.26, particularly 680.26(A)FPN.
Old 08-30-2008, 05:08 PM   #3
Thanks very much for your help, just one more thing i do need to run a #12 ground with the feeders yes or no? you have been a great help .
i thought that it was permisable to run cable up until the point of exiting the house ,being it had a ground wraped in the outer sheath of the cable.
theres only one problem how the heck do i get pvc or other conduit thru a finished basement ,lol! i guess i`ll worry about that later .
Old 08-30-2008, 06:12 PM   #4
Electrician
Originally Posted by sparky62 View Post
Thanks very much for your help, just one more thing i do need to run a #12 ground with the feeders yes or no? you have .
Your pulling a 20amp feeder for your pool sub-panel? Your very weak in the 680 section, I would have started with an above ground pool to get your feet wet, no pun intended.
chris75 is offline   Reply With Quote
Old 08-30-2008, 06:19 PM   #5
You must size the ground according to the feeder, but it must be insulated and not smaller than #12.
That applies to motor branch circuits, NOT feeders.
Old 08-30-2008, 08:23 PM   #6
chris you totaly don`t understand yourself , i think you need a course in reading
Old 08-30-2008, 08:25 PM   #7
Thanks your the only one who understands , thats all i needed to know plain and simple! you know the reason people have trouble with the code is interpertation ,not lack of skill in the trade per se. thanks again!
Old 08-30-2008, 10:22 PM   #8
Electrician
Yep, i'm the bad guy. Just remember, I will answer any question you have on your job, like I have at Mike Holts site already.
Wiring from panel Rick N. Electrical 6 07-10-2013 05:25 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
