Old 11-08-2012, 08:36 PM   #1
Smile
Wiring for a sub panel
Hi, we built an addition and an attached garage to our home.
If we have are installing a 100 amp sub panel in the garage
Do we need to have a 100 amp circuit breaker on our main panel and
Can we use #2 wire from the main to the sub panel. It is going to run along
Our unfinished basement ceiling and then through conduit along the outside of the house up and into the garage where the sub panel will be. ( it will all be in conduit from the main until it comes inside the garage. Any help you can give will be appreciated! Thanks
Pollardmd is offline   Reply With Quote
Tags
circuit breaker, sub panel, wiring
help wiring a panel ex-28 Electrical 17 01-27-2012 03:51 PM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 11:49 AM
wiring sub panel right next to main panel bill423 Electrical 4 05-14-2011 09:17 PM
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 10:50 AM
Sub panel wiring question mntnvew Electrical 13 03-02-2009 12:28 PM
