#1 |
Wiring Sub Panel
I have a 240 volt power supply. I'm installing a 100amp sub panel. I only need 120 volts out of the panel. How do i wire the 240 volt power supply in the homelite sub panel and have 120 volts at the breakers?
#2 |
"So I Re-Wired It"
Wiring Sub Panel
Do you understand how 120/240 works?
IMO if you need to ask such questions, perhaps you should call a pro Maybe im just reading the question wrong. Please explain more.
Knowledge is Power, but 240v can Keel You!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to MisterZ For This Useful Post: | gregzoll (08-15-2012) |
#3 |
Master Electrician
Wiring Sub Panel
You require two hots a neutral and a ground at the new panel location.
Is the subpanel located in the same building. What size wire did you run? Need more info.
Sarcasm is my friend I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own. |
#4 | |
Wiring Sub PanelQuote:
That said, if your understanding of electricity is very basic, a sub panel is probably not the job to cut your teeth on. I would, as others have recommended, call an electrician to help you out. And I can't emphasize enough that I don't mean that as an insult I'm just concerned about ya safety wise. |
| Display Modes | |
| help wiring a panel | ex-28 | Electrical | 17 | 01-27-2012 03:51 PM |
| Sub Panel GND and mixed 240/120 VAC branch | curiousB | Electrical | 12 | 01-17-2012 11:49 AM |
| wiring sub panel right next to main panel | bill423 | Electrical | 4 | 05-14-2011 09:17 PM |
| Wiring a sub panel to another sub panel | Uncle Wayne | Electrical | 25 | 02-08-2011 10:50 AM |
| Sub panel wiring question | mntnvew | Electrical | 13 | 03-02-2009 12:28 PM |
