-   -   Wiring Sub Panel (http://www.diychatroom.com/f18/wiring-sub-panel-153815/)
bobkbb10 08-15-2012 06:24 PM
Wiring Sub Panel
I have a 240 volt power supply. I'm installing a 100amp sub panel. I only need 120 volts out of the panel. How do i wire the 240 volt power supply in the homelite sub panel and have 120 volts at the breakers?:(
MisterZ 08-15-2012 07:22 PM
Do you understand how 120/240 works?
IMO if you need to ask such questions, perhaps you should call a pro;)
Maybe im just reading the question wrong. Please explain more.
andrew79 08-15-2012 07:26 PM
You require two hots a neutral and a ground at the new panel location.
Is the subpanel located in the same building. What size wire did you run? Need more info.
LooseSCruz 08-15-2012 08:59 PM
The 240v supply is divided across the two phases in the sub panel, each of which measures 120v from phase to neutral. A standard single pole circuit breaker connects to only one phase and, therefore, supplies 120v.
That said, if your understanding of electricity is very basic, a sub panel is probably not the job to cut your teeth on. I would, as others have recommended, call an electrician to help you out. And I can't emphasize enough that I don't mean that as an insult I'm just concerned about ya safety wise. :thumbsup:
