wiring a stove
In addtion to above comments I know you will say oh no not again.,,
Anyway if you have alum conductors you will have to pay special attetion to the splices when you do them in the junciton box can not use the standard wirenuts it have to be either split bolts or poilars connector block one of the two will meet the requriement and also get 4X4 or 5X5 { C'est 4 11/16 box }
And watch the ampcapity rating on alum verison the copper verison is not too bad but if you get the conductor size here a quick run down
Copper verison { typically }
#8 40 amp
#6 50 amp
Alum verison
#8 30 amp
#6 40 amp
So just watch out on them the tinned copper sometime can fool ya think it is alum but not always the case the alum will have plastique coating while copper tinned will have either rubber or plastique coating on it.
Hope that help along the way.
Merci,
Marc
