Wiring Solid State Fan Controller - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 02:17 PM   #1
I am planning the wiring of a solid state fan controller I got for my greenhouse exhaust fans.
The wiring diagram included for my model is attached.
My model is this one, albeit I didnt get it from this place:
http://www.amazon.com/Electronics-Va.../dp/B000F9HHTI
Can anyone give me a synopsis of how I should wire this up to my break box? I have a 15 AMP breaker, 12/2 wire (might have some 12/3 available too, maybe), the controller and the conduit to run it.
My quandry is that I have two fans, 4.5 AMPS each, SS controller is 15 AMP, so I wanted to have two recepticales that would be powered via the SS controller so that I could plug the exhaust fans into the outlets and have them both controlled from the single controller. The fans are corded and not long enough to reach each other for a single recepticle unless I use extension cord.
Thoughts?
HELP!!! My plants need air
mntnvew is offline   Reply With Quote
Old 07-16-2010, 04:32 PM   #2
Not to be used with Capacitor Start or Capacitor Run Motors
Applications: Fans, Blowers, Fireplace Blowers, Attic Fans, Humidifiers, Ventilators
for shaded pole and PSC motors.
Motor must be run with sufficient torque to prevent stalling
I would fuse each motor separately at 6 A or so to protect the speed control. You may have to experiment with fuse size and whether its reaction time is normal blow, fast blow or 'slo-blo'.
Can you post links to your fans?
Old 07-16-2010, 04:48 PM   #3
Fans
These are the fans I have, I purchased them from this site.
I have the 24" 1-speed (REQUIRES SPEED CONTROLLER) one.
http://www.teksupply.com/farm/suppli...62_104665.html
(this is direct link to the one I have)
Here is information PDF on these fans. I have the last one listed in the chart at the bottom of the file:
http://www.teksupply.com/wcsstore/En...2_63_64_65.pdf
Old 07-16-2010, 04:52 PM   #4
Both motors have capacitors. If they are Permanent Split Capacitor [?] I guess they OK for this control. Try their toll-free numbers to get answers.
Old 07-16-2010, 04:54 PM   #5
This is the controller they told me would work for these TWO fans together, because of the 15 AMP vs. the smaller controllers that are much lesser amerage.
So as far as wiring goes... can I just run 12/2 from the 15AMP breaker to a junction box and then split from there off to the controller and the outlet(s)?
Old 07-16-2010, 05:07 PM   #6
1
2
1 then you're set, but at one speed control setting the airflow from each fan may not be the same.
2 I hope an electrician will chime in on this question. I'd just use an extension cord at these low currents.
Old 07-16-2010, 05:12 PM   #7
OIC, your saying that the power coming out of the controller may not be split equally between the outlets so I should just use a single outlet and run an extension cord from that, just one that has a multiple connector end, to the fan cords.
Right?
Old 07-16-2010, 05:31 PM   #8
Both fans will see the same RMS voltage from the chopped up sine wave you get from Triac speed controls
but since they are not identical they will probably not have the same CFM because they will have different current draws.
Even if the current draw is the same for each fan, the Fan Curve for each is probably different so again you'd get different CFM.
Before you do any permanent wiring try each fan at different speed control settings. You may want two separate speed controls.
You can also put a resistor or inductor or incand. lamp in series with the motor to slow it provided that the motor can tolerate this method, but UL and the NEC will have a conniption over this idea. You didn't hear it from me!
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
Electric wiring AMPIN88 Electrical 1 02-21-2009 11:31 PM
State Vehicle Inspection - ARGGH Leah Frances Off Topic 14 04-05-2008 01:59 PM
Permit application harder than the wiring job itself - WA State blschmitz Electrical 2 01-18-2008 08:36 PM
