Wiring In Soffit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2012, 11:58 AM   #1
Wiring in soffit
I have a 32 ft long soffit built around an I-beam and HVAC trunk line in my basement ceiling. Construction is 2x4 on the flat side. Can I use this as a chase for my wiring? If so do I attach(and how) to the pocket inside the I-beam or can I run it along the bottom or side of the soffitt and attach there since it would be 1 1/2" thick.
Thanks,
Jeff
jeffh110 is offline   Reply With Quote
Old 04-13-2012, 12:43 PM   #2
is the soffit finished or unfinished?
itsnotrequired is offline   Reply With Quote
Old 04-13-2012, 02:53 PM   #3
Master Electrician
Rewards Points: 3,920
Thanks,
Jeff
Yes. Use the top side of the bottom framing of the soffit.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
plummen (04-13-2012)
Old 04-13-2012, 03:13 PM   #4
Currently unfinished, will be drywalled. I assume staple to the bottom at standard 4 1/2ft spacing.
Thanks.
Old 04-13-2012, 03:31 PM   #5
Licensed electrician
Rewards Points: 1,794
I have installed short pieces of 2x in between the flanges of the beam and stapled the wires to the 2x's.
Old 04-13-2012, 07:25 PM   #6
Missouri Bound's Avatar
Won't be a problem using it as a chase. No junction boxes enclosed behind drywall or any structure.
Do you want it your way or the right way?
Hidden Soffit Vents Mucluk Building & Construction 4 01-26-2012 08:15 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
Knee wall w/ soffit vents no ridge vent -- seal soffit vents? tblaz Roofing/Siding 1 04-24-2011 04:12 PM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
