Wiring In Sips Panels - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2009, 02:26 PM   #1
R_T
Wiring in sips panels
I'm looking at a rather large new construction job (10000 sqr ft residence) that will be using sips panels for exterior walls and the roof. Has anyone had experience with this type of install and would you be willing to tell me an added time difference versus romex in wood framing. Any other thoughts, tips, etc. would be welcomed.
TIA
R_T is offline   Reply With Quote
Old 11-19-2009, 02:49 PM   #2
Remodeling Contractor
depends on the experience of your electrician. Wiring is done through prepared wiring chases. It does take about 15% longer and you do get lost time, since some connections need to be made as the work of installing the panels takes place. Another thing to consider is where will all the electrical outlets be placed. As long as they all conform to where the panels have planned for them you will be fine.
Old 11-19-2009, 03:24 PM   #3
Rewards Points: 1,910
Search the postings on this site for more info:
http://www.greenbuildingtalk.com/For...s/Default.aspx
It looks like for exterior walls you'd have to do some fishing through prexisting channels in the panels rather than drilling and threading. You might route wires a bit differently for efficiency. Interior walls of course would be no different.
There is an interesting technique called "hot balling" for putting in vertical channels.
I didn't see anything about having to wire during panel assembly but I think Bob is a builder so he would know.
Old 11-19-2009, 08:44 PM   #4
This only happens when changes to the plans are made after delivery and if things are missing.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Structured Wiring Panels ctsmiths Electrical 18 02-17-2009 10:34 AM
