Wiring From Shower To Towel Rail - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2009, 04:31 AM   #1
Wiring from Shower to Towel Rail
Hi.
I have an old electric Mira shower 240v 7kw which is now disconnected.
I would like to install a small electric radiator 230v 300w.
Can I use the same cable which connected the shower to connect the radiator instead?
Many Thanks.
Liz.
lizm73 is offline   Reply With Quote
Old 04-28-2009, 07:28 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
Well, considering that the cable to feed a 7000 watt load is considerably larger than one that would be needed to feed a 300 watt load, it could be done I guess, but it would be a pain.
Some of those towel warmers have very small junction boxes. This may be an issue.
Old 04-28-2009, 06:40 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Are you in USA or in European area?
It can be done however the conductor size it will raise ugly " rear end " with connection if the shower oringal conductors were at #8 { 10mm˛} it can be very tricky to termatation to the towel racks due the junction box it can be pretty small { I allready did see it before it is not any bigger than 3/4 size of the handibox size }
However if You are in UK that circuit it still must be on RCD{ GFCI }.
Merci,Marc
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 01:42 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
shower curtain rail, but sloping ceiling Hazel Interior Decorating 2 11-07-2008 05:46 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
Hanging towel rail without stud peter1 General DIY Discussions 11 03-11-2008 11:54 AM
