Wiring A Shop Light - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 08:00 PM   #1
Rewards Points: 77
Wiring a shop light
Wiring a shop light to a dedicated switch.
Got a black, white, and yellow coming from the light.
Sheet in the box says,
"If fixture is to be switched from wall switch, make sure that the black power supply wire is connected to the switch. DO NOT connect the white supply wire to the switch."
Got a black, white, and ground coming from the panel.
Got a black, white, and ground coming from the switch.
Confused by the yellow (expected a ground) and the quoted instruction.
dcj710 is offline   Reply With Quote
Old 09-19-2012, 08:16 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,608
Can you see where the other end of the yellow wire goes to ?
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
dcj710 (09-19-2012)
Old 09-19-2012, 08:18 PM   #3
Rewards Points: 14,312
The yellow was suppost to run from the ballest to the lamp holder.
dcj710 (09-19-2012)
Old 09-19-2012, 08:39 PM   #4
Rewards Points: 77
One yellow does run to the lamp holder. I boxed it up; I'll take another pic tomorrow and post it.
Old 09-19-2012, 08:41 PM   #5
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
The yellows, reds, and blues connect to the lamp holders. The black and white are your power wires. Attach the ground to the grounding screw inside the fixture. The diagram is on the ballast.
John
jrclen is offline   Reply With Quote
The Following User Says Thank You to jrclen For This Useful Post:
dcj710 (09-20-2012)
Old 09-20-2012, 08:21 AM   #6
Rewards Points: 77
Yellow...
Sure enough, the other yellow did go to the lamp holder. Must of fell out at some point pulling it out of the box. Similar to a receptacle back stab.
OK. So, what's the quoted text referring to? -- "...DO NOT connect the white supply wire to the switch"?
Old 09-20-2012, 09:36 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
"OK. So, what's the quoted text referring to? -- "...DO NOT connect the white supply wire to the switch"?"
All that means is you must switch the hot lead (black) and not the neutral (white).
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
dcj710 (09-20-2012)
Old 09-20-2012, 09:58 AM   #8
Rewards Points: 77
Thanks. And, John, I saw the diagram on the ballast, but I guess it's time to step up a notch or two in readers. Couldn't make out what it said, and wasn't about to ask my wife. Got it up and working...thanks again.
Old 09-20-2012, 04:46 PM   #9
jrclen's Avatar
Rewards Points: 514
I'm glad you got it working. I'm happy to help.
John
dcj710 (09-20-2012)
Adding Light Switch - Outlet - Light > Correct wiring ? westbank Electrical 4 09-15-2012 10:42 AM
T5 Shop Light Wiring Orange Plug? cre10 Electrical 21 10-06-2011 03:19 PM
Basic light wiring question speedster1 Electrical 3 11-29-2010 06:48 PM
Wiring Shop Scrubbie Electrical 6 03-09-2010 06:23 PM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 06:25 PM
