Wiring A Shed, Need Advice. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 05:40 AM   #16
thanks everyone!
dumbplumb, i like the details you gave.
Is this the type of 6-3 i will need?
http://www.ebay.com/itm/UF-B-6-3-Und...item2ea92d6ccf
Also, what size and how many breakers will be added to my current home panel.
I completely understand how to wire the outlets & switches, but if someone could expand or even provide a diagram of how to wire the 6/3 on the home panel end, and at the shed on a 50amp sub panel. my home panel is a cutler hammer.
hgbpro is offline   Reply With Quote
Old 02-02-2012, 05:47 AM   #17
Rewards Points: 3,256
Originally Posted by Julius793 View Post
Your right I redid my post.
I think you need to edit again. Remember the number six (6)?
zappa is offline   Reply With Quote
Old 02-02-2012, 05:58 AM   #18
Julius793's Avatar
Yes up to six breakers is considered a main. I guess I forget who I'm dealing with.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-02-2012, 06:46 AM   #19
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
You still need a disconnecting means for the detached shed, via a switch, or disconnect mounted before the panel.
Old 02-02-2012, 06:55 AM   #20
Licensed electrician
Rewards Points: 1,632
I don't think the OP even needs a 10-3 to the shed based on the proposed loads.
Old 02-02-2012, 07:53 AM   #21
Sorry Julius, I should have kept my trap shut as I didn't know this.
jbfan.....where did the 6 throw rule come from if a disconnect near the panel is still needed?
Old 02-02-2012, 08:00 AM   #22
Julius793's Avatar
Nothing to apologize about. The way I remember 225.32 and 230.71 you are correct.
Old 02-02-2012, 09:25 AM   #23
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You could always run the wire in conduit and if you decide to upgrade you can just pull larger wires. Use at least one inch conduit and you will be ok. I can't remember how many times someone has refused to go larger or pay enough to have the wire in conduit. Then a couple years later find out they outgrow it.
Also don't forget to use expansion couplings whenever you go from the building into the ground.
rrolleston is offline   Reply With Quote
Tags
building , garage , shed , utility , wiring
wiring a shed jay3131 Electrical 0 06-19-2011 10:54 AM
Advice: Shed Plans/Insulation Question lukabrazi Building & Construction 16 01-23-2011 07:02 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 07:04 AM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
