Wiring A Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 02:47 PM   #1
Rewards Points: 35
Wiring a shed
I built a shed a few months ago and now I'm planning on running power to it, instead of the 3 extension cords I'm using now.
I've read the Black and Decker electrical book and talked to a few people but i keep getting different info. I've talked to commercial electricians on jobs, residential electricians at Lowes and Home Depot, and a retired Dupont electrical engineer. Now i need more info.
My plan was to run direct burial aluminum 2/2/4 to the shed, 60 amp panel in the shed, 1-15 and 2-20 circuits, run wire from the panel straight up to the attic area then around and down for receptacles, 2 ground rods behind the shed.
The latest I've been told is I need to use 2/2/2/4 wire, might as well do a 100 amp panel, I don't need a GFCI coming from the house or in the shed panel since my shed isn't sitting directly on the ground, i can just use one GFCI receptacle on each circuit to get the same results. This was from a 40 year residential electrician.
Anyone have any input? Thanks in advance.
DavidKulzer is offline   Reply With Quote
Old 03-18-2013, 02:52 PM   #2
Licensed electrician
Rewards Points: 1,054
Unless you are planning for much larger loads that size feeder is way bigger than it needs to be.
The feeder will need to be 4 wires. You will need the grounding electrode system for the shed also.
Old 03-18-2013, 03:24 PM   #3
Rewards Points: 3,130
I have done something similar. I used AWG 6 THHN/THWN in conduit. My "shed" is actually a finished space with heat and air conditioning; it's my wife's art studio. Not sure what code says you can do if you don't need 240v power (she has a pottery kiln so needed that).
Old 03-18-2013, 03:49 PM   #4
Rewards Points: 35
Copper was my original plan but it's over twice the cost of aluminum. Even more when you factor in conduit and my shed being about 110 feet from the house. I'll be running normal tools out there, miter box, table saw, air compressor, etc. I have a propane heater out there now but would like the option for electric and AC. The aluminum wire is about $1.40 a foot and rated for more amps. I guess that's why it was suggested.
What is the grounding electrode system?
Old 03-18-2013, 05:02 PM   #5
" I used AWG 6 THHN/THWN in conduit."
Copper and single conductors in conduit is the way to go. Dig once and pull once. Also bury a 3/4" conduit for any other type wire such as cable, cat5 and such.
Aluminum is bad news!
Hardway is offline   Reply With Quote
Old 03-18-2013, 07:27 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
That's just nonsense....
Old 03-18-2013, 07:45 PM   #7
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
[QUOTE=Hardway;1140221
[/QUOTE]
Funny. I ran 200' of 500 kcmil AL underground to my house 28yrs ago and have never had any problems.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
stickboy1375 (03-18-2013)
Old 03-18-2013, 07:45 PM   #8
Rewards Points: 35
Aluminum brings power to your house. Can't be but so bad. I'm pretty broke so anywhere i can save money and still be safe and get the job done sounds good to me. I do like the idea of a separate conduit for cable and internet though, even though my wifi reaches out there somehow.
Old 03-18-2013, 09:07 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
After taking into consideration the OP's situation, I would run a 1" or 1 1/4" PVC with 4 #8's on a 2P 50A breaker. This would be plenty for what you are running currently, and the conduit is large enough that if you ever increase the load in the shed, you can pull larger wires and install a larger breaker.
Old 03-18-2013, 09:23 PM   #10
No it is perfect sense; Aluminum will fail over copper every time.
Aluminum is prone to corrosion and poor connections. Chevy used aluminum wire for the tail lights under the carpet and it would fail the aluminum would turn to a paste. Aluminum in the ground is subject to fail, just as the line is from poll to house leading to poor connections. Why use Aluminum the same reason the POCO, cost cutting.
Old 03-18-2013, 09:26 PM   #11
The POCO use Aluminum to cut cost.
I did not say it was not safe, I said it will fail over copper.
Old 03-18-2013, 09:31 PM   #12
E2 Electrician
That is your opinion and you are entitled to it, as I am.
I know with that comment that you are not a contractor, or anyway involved in the electrical business or installation.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Baxter01 (03-18-2013)
Old 03-18-2013, 10:04 PM   #13
I can understand cost saving. I did not say it was not safe!
You have to go with what you can afford.
Old 03-18-2013, 10:09 PM   #14
Contractor = Money If you can't price the job right you don't get the job. With the price of copper I understand it
Old 03-18-2013, 10:12 PM   #15
E2 Electrician
im not sure what you're saying? I just don't have any issues with AL, nor should I....
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Wiring to shed question Burbman Electrical 26 04-06-2012 11:05 PM
Conduit questions in shed wiring TheCowGod Electrical 28 03-18-2012 02:42 PM
wiring a shed jay3131 Electrical 0 06-19-2011 11:54 AM
wiring electrical in a shed patrick29 Electrical 11 08-22-2009 04:46 PM
