Wiring A Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 02:10 PM   #1
Question
Wiring a Shed
I'm sure this question is somewhere in here, but like everyone else, my project is a bit different. Here is what I want to power in my shed:
4 light fixtures (60w) w/2 switches
1 table saw (13A)
1 router (8.5A)
1 miter saw (15A)
Of course, not all being used at the same time
1 shop vac (8.8A, used when a tool is used)
1 well pump (8.5A)
1 pool pump (15A???)
Being used at the same time often
Small radio
Black and Decker 18V battery charger
12V slow trickle boat battery charger
I have included my simple drawing (power point slide) of what I would like to do. At a minimum, I would call myself am a little better than ignorant when it comes to wiring and electricity, but I went to catholic school and I can read.
I want 3 dedicated lines for the well pump, pool pump and a tool outlet.
The shed is spilt into 2 sides (9X20 each), right side is weather tight, on a slab. The left side is dirt floor, 9X5 slab in the back, with a few plexi windows and two rows of clear roof tile so my wife can grow flowers (homemade attempt at a quasi green house)
The shed is about 80' away from the main panel in the house.
I was thinking UF-B 8/3 to the shed, 6 circuit sub panel.
Is this enough power for what I want? What flaws do you see in my idea? What am I over looking?
Please go easy if I am way off with my drawing or idea, remember, I am an extreme novice.
Thanks for your help and comments.
Joerigger is offline   Reply With Quote
Old 01-14-2012, 02:12 PM   #2
Rewards Points: 14,020
No mention if any of those pumps are 220 volt.
Old 01-14-2012, 02:13 PM   #3
Everything is 115/120
Old 01-14-2012, 02:17 PM   #4
Rewards Points: 6,652
If it was me, I would be running a 60 amp circuit out there.
Tags
novice , shed , wiring
Wood Shed Construction- Town wants concrete pad? TJ_in_IL Building & Construction 20 07-26-2011 09:21 PM
Shed Started, Issues with Zoning Rock8Reno Building & Construction 17 07-16-2011 06:06 AM
wiring a shed jay3131 Electrical 0 06-19-2011 10:54 AM
wiring electrical in a shed patrick29 Electrical 11 08-22-2009 03:46 PM
water run off in shed kathy k Building & Construction 4 08-09-2009 03:29 PM
