Wiring A Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 11:54 AM   #1
wiring a shed
hi can anybody give me some tips i have a light in my shed and put in a double plug socket (RING FINAL CIRCUIT) i need to run a wire from the plug socket in the shed and somehow join the wiring to the existing security wiring light can it be done with a joint box my plan is see below
from the double socket in shed feed pvc cable with a earth, live and negative wire through hole then run along out of shed and secure with plastic clips then under a slab with plastic tubbing up the wall of the house then spilt security lighting wire and join with a joint box do i use 2 way or 3 way and conect all wires to joint box plus do i need to put a higher rate fuse in the cosummer unit box for the downstairs plug sockets? or would my idea be dangeress?
jay3131 is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Wood Shed Construction- Town wants concrete pad? TJ_in_IL Building & Construction 20 07-26-2011 10:21 PM
wiring electrical in a shed patrick29 Electrical 11 08-22-2009 04:46 PM
water run off in shed kathy k Building & Construction 4 08-09-2009 04:29 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
