Wiring Scheme For Mini Split A/C - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 08:18 PM   #1
Wiring Scheme for Mini Split A/C
I received a Shinco mini split a/c unit and was looking at the wiring diagram which is for 230v. The diagram shows only three wires from the power supply to the outdoor unit (L1,L2,G). I assume that L1 and L2 are the two hot wires and G is the ground wire but where does the neutral wire go? There are no connections labeled for the neutral on the unit, only the three I mentioned.
Wiring Scheme for Mini Split A/C-wiring-pic.jpg
dmcclur3 is offline   Reply With Quote
Old 01-20-2010, 08:31 PM   #2
A 240 volt appliance would not need a neutral.
A neutral would be used to supply 120 volts.
Some appliances might need both 240 and 120 volts. And in that case they would tell you to also run a neutral.
And BTW, this unit does say "60 cycles"? (Some of these are made for foreign countries which have 50 cycles electricity.)
Billy_Bob is offline   Reply With Quote
Old 01-20-2010, 08:39 PM   #3
it is 60hz. What would I do with the neutral wire, just disregard it and leave it disconnected ?
Old 01-20-2010, 09:01 PM   #4
Yes you could leave it disconnected but also put a wire nut on it...so the end can not come in contact with anything.
http://www.electriciansgangbox.com/blog
ElectGangBox is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
mini split Wiring question??? mjebril HVAC 5 08-02-2009 06:31 PM
Celiera 18000 Split AC/Heatpump, power wiring diagram? trinhyulinh HVAC 2 08-03-2008 12:36 PM
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 07:12 PM
