Wiring For Satellite TV - Electrical - DIY Chatroom Home Improvement Forum
Old 05-07-2012, 03:02 PM   #1
Wiring for Satellite TV
I am getting ready to begin wiring my newly framed basement with coaxial cable for my satellite tv. However, I have a question as to the best location to place my coaxial wall plate. I was thinking of placing it on the opposite side of the same stud that my electrical outlet is attached to. However, I'm not sure if this is too close to the electrical outlet which I've heard can cause interference. Any help would be apprecated.
Stein is offline   Reply With Quote
Old 05-07-2012, 03:07 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Opposite sides of the studs is pretty much standard procedure for this type of install. In fact, as options have come available, it is now common to use the same box (with approved divider). You shouldn't have any problem with interference.
Old 05-07-2012, 03:08 PM   #3
kevinp22's Avatar
that is how mine are wired and I have never had an issue with interference. I think it looks tidier as well.
Personal preference.
kevinp22 is offline   Reply With Quote
Old 05-07-2012, 03:14 PM   #4
k_buz's Avatar
Do yourself a favor and run a Cat5 cable to the TV from your router or modem. DirecTV requires an internet connection for on-demand type programming. On top of that, many new TV's are also internet ready, so you might want to run 2 Cat5's.
Old 05-07-2012, 03:18 PM   #5
Thank you. I agree that it looks tidier.
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 10:51 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
