Wiring A Room - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2013, 01:13 PM   #1
Rewards Points: 18
Wiring a room
I have a room with two lights (one light and one fan/light) operating on one switch. I'd like to put each light on its own switch and into a two gang box. In the switch box I have three 14-2 wires coming out. In the fan/light box I have two 14-2 wires, and in the light box I have one 14-2 wire. I'm not sure where my power supply is coming from and not sure the next step and correct wiring. Any help is appreciated.
Gburg109 is offline   Reply With Quote
Old 12-29-2013, 01:39 PM   #2
Licensed electrician
Rewards Points: 1,024
You are going to need to find out the function of each cable to see how connections can be changed or if new cables need to be run.
Old 12-29-2013, 03:20 PM   #3
how is the fan controlled? is there a separate switch from the lights? if so, what wire is present at that switch?
itsnotrequired is offline   Reply With Quote
Old 12-29-2013, 03:26 PM   #4
Rewards Points: 18
One switch control everything. Both the light fixture and the fan/light. I want to be able to turn off all lights and keep the fan able to run.
Old 12-29-2013, 03:29 PM   #5
so the fan is always on/off when the lights are on/off, respectively?
Old 12-29-2013, 04:35 PM   #6
Rewards Points: 18
Yes that is correct.
Old 12-29-2013, 05:01 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I would think the switch box has power in on a 14/2, power out on a 14/2 (to other receptacles) and switched power to the fan on the 3rd 14/2. At the fan/light box you have switched power in on a 14/2 and switched power out to the light on the other 14/2. You can not do what you want with the existing cables. You need to install a 3g ang box for 3 switches and run a 14/3 from the switch to the fan. A switch for each light and a switch for the fan.
Coastal South Carolina
primarily dining room questions, but a few others Tonglebeak Electrical 6 04-25-2013 10:24 PM
Wiring of Dining Room Fan Sycamore Inn Electrical 16 09-29-2011 02:21 PM
Wiring a new living room addition ryan5068 Electrical 3 06-25-2011 06:09 PM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 05:47 PM
Upstairs room gets hot... olcottke HVAC 6 08-13-2010 02:57 AM
