Wiring Replacement Microwave - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 10:43 PM   #1
Wiring replacement microwave
I apologize off the bat as this post may get wordy. I am replacing an over-the-range microwave with a new one. The house originally had a regular range and an over-the-range convection oven. The convection oven was long ago replaced by an over-the-range microwave, but it appears that the original 220 wiring to the convection was also used for the microwave. Within the breaker box, the white/black wires on this circuit were dedicated to the microwave, and the red wire was left loose, hanging in a coil at the bottom with a tag that reads: This conductor is spare in the microwave oven recpt. However, and this is my concern/question, when I test the red wire, it has continuity. Can I install the new microwave using this same wiring configuration? Is the red wire creating a potential fire hazard? All replies are appreciated. Thank you in advance for your help!
kgreer313 is offline   Reply With Quote
Old 12-07-2011, 11:01 PM   #2
joed's Avatar
Rewards Points: 11,976
There is no problem leaving the red wire disconnected at both ends.
What gauge is the cable? #12 is good for 20 amps. #14 is good for 15 amps.
Old 12-07-2011, 11:08 PM   #3
It has continuity with what?
jammin06 is offline   Reply With Quote
over-the-range microwave problem aumanpj Appliances 6 12-04-2010 06:46 PM
OTR Microwave -> Range hood wiring A for Effort Electrical 2 07-31-2010 11:00 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
