Wiring To Replace Timer Switch With Single Pole Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-20-2012, 12:52 PM   #1
Wiring to Replace Timer Switch with Single Pole Switch
Have a timer switch that stopped working. Bought a newer model, but the size is bigger and won't fit in electrical box. Now looking to replace with a simple single pole switch.
The box has a 14/2 (black/white) wire entering bottom, and a 14/2 (black/white) wire exiting top as well as a 14/3 (black/white/red) wire exiting top.
All wires and switches had grounds hooked up, but I will ignore for this conversation.
The original time switch had a red, black and white wire exiting it.
The box was wired as follows:
- All 4 black wires were together in a wire nut.
- All 4 white wires were together in another wire nut.
- The two red wires were connected in a wire nut.
I assume the red wire in the 14/3 wire feeds the light that the timer switch controlled. Not sure what is fed by the other 2 black wires exiting box.
I removed the old timer switch and wired a single pole switch as follows:
- All 3 black wires were together in a wire nut. I then pig tailed the black wires to one of terminals on the switch.
- All 3 white wires were together in another wire nut.
- The 1 red wire was connected to the other terminal on the switch.
When I turned the circuit breaker back on, and then turned the light switch on, the circuit breaker immediately turned off.
What's wrong with this wiring?
BusterT is offline   Reply With Quote
Old 10-21-2012, 07:49 AM   #2
You have a short on your red wire if the switch is off and the breaker stays on. Check to see if your red wire got skinned. Your 14-2's would be your power in and power out to another switch down the line.
j-ska is offline   Reply With Quote
Old 10-26-2012, 03:39 PM   #3
I think that was it, a short
I removed switch and undid the wiring. Inspected wires and they appeared to be fine. Tested with multimeter and what I suspected was right as to which wire was the feed and which went to the light in question. I did notice the ground wire off the switch was bare, so I replaced with a sheathed wire, rewired switch and now its works.
My speculation is that the bare ground was touching a terminal on the switch and shorting it, if that's possible.
Thanks for your help.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Wiring help for a timer switch (for bathroom exhaust fan)! vanny Electrical 12 07-10-2012 08:58 PM
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
