Wiring Remote Controlled Ceiling Fan Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2014, 05:29 PM   #1
wiring remote controlled ceiling fan wiring question
Hi i have a quick question about a ceiling fan i installed yesterday. I replaced an older model fan with a new model with a receiver and remote. the electrical box in the ceiling had a black wire, a ground wire, a red wire and a white. the black wire was constant power and red was power from the single wall switch to the fixture. i wanted use of the wall switch as well as the remote with the new fan so i capped the constant black wires and used the red as power. everything seems to work good now except when i turn off the new fan/light with the wall switch the fan makes a fairly audable click. when i flick the switch to the on position everything turns on with no noise. is this something to be concerned about? I am kind of thinking the click is from cutting power to the receiver in the fan and i know a typical instalation for this type of fan uses constant power.... Thanks for any help!
mattalbert is offline   Reply With Quote
ceiling fan wiring jmon Electrical 3 07-14-2013 06:52 PM
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 07:52 PM
Ceiling fan remote issues Richo Electrical 7 06-06-2011 09:09 PM
New Ceiling Fan Wiring Please help Akkasca Electrical 2 07-23-2010 12:44 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
