Wiring Recessed Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2012, 02:10 PM   #1
wiring recessed lights
A quick wiring question about recessed lights. The picture below shows the lights that I'm going to use. There are Two ground wires! Do I pigtail them together or just use one? The black and white obviously are for the power. Why did they do it this way?
UFoPilot is offline   Reply With Quote
Old 03-31-2012, 03:08 PM   #2
Rewards Points: 264
Yes, the green wire, the bare wire, and the ground wire from the incoming power need to be connected together.
What you actually have here is the bare wire providing an equipment ground to the fixture itself. The green wire is bonding the junction box to the ground. The green wire is needed in case one of the other wires in the box somehow contacts the box. The bond provides a low resistance path back to your panel so the breaker will trip instead of the junction box sitting there hot for anyone passing by to touch.
a_lost_shadow is offline   Reply With Quote
Installing remodel recessed lights in manufactured home. MikeVila Electrical 14 08-03-2011 07:06 AM
Wiring 6 Recessed Lights in Kitchen shawjd1 Electrical 3 01-27-2011 07:53 PM
wiring several recessed lights from 1 switch raineydr Electrical 14 03-15-2010 08:52 AM
How Many Recessed Lights SHould I use? jonathan03 Electrical 0 03-14-2010 11:03 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
